Could you check the values for this current source?
There have been a couple of changes in this part of the Baby Huey schematic.
It should sink around 2 to 2,5mA of current. Are these resistor values ballpark?
I'm asking because there have been a couple of changes and I have zero knowledge of transistors.
The values in the schematic and what is on the pcb differ.
Yes, current about 2mA, that is 1mA pro triode.
That's to much with anode resistors of 220k and 300V power.
Drops 220V, leaving 80V for the ECC83, no good.
Keep R18 at 1k as original, gives aprox 0,6mA triode current.
R16 provides the base current and with R17 divides the -12V over the two transistors.
No need to use 2N5551, simple BC547 or BC548 is ok.
Mona
I suppose the kathode of the LED is on a negative potential,
so R16+R17 determine the LED current from GND to V- and
R17 generates also the voltage for Q12 (cascode with Q2)
Daanve is right: to be safe better measure the voltage across R18
