There are a thousand ways to skin a cat and indecision is stopping me from making some subs.
Currently running full range drivers so looking for some stereo subs to handle low end, but can be crossed higher. Probably run Hypex Fusions for DSP/amps. Uk availability if possible.
Can anyone recommend (regardless of cab design, and can include any style but please include if they require certain design restrictions) the best subwoofers for for the below budget;
£50
£100
£200
£50
£100
£200
Are you looking for drivers, or a finished subwoofer?
Either way, £50 isn't going to get you much unless you really scour the 2nd-hand market.
Chris
Chris
60Euro, Mivoc-Lautsprecher AWM 104
Used in sealed and then EQed
or
Tapped Horn Plans – Volvotreter Homepage
or
Front Loaded Horn
Sim it in Hornresp
or
or
Front Loaded Horn
Sim it in Hornresp
I guess I don’t really care.
I guess I was trying to see if there was a standout cone or design from the hive mind here.
I guess what I want to know is, if you threw on £50 for birch Plywood cabinets, then what is the best subwoofer you can get for the above +£50.
Choice paralyses is becoming a problem...
Well, I'd be looking at something like a JBL GTO1214 and build a Kraken tapped horn for it.
Chris
Chris
- Subwoofers
- £50-£200 subs best choices.
