My B226 has difficulty to start playing a CD. Actually, it won’t start if I do not help it by gently moving the swing arm away from the spindle motor so that it can read TOC and start playing.
Here is how it behaves: when I insert a CD and press PLAY, disc will rotate clockwise for a second or two and then give up. Sometimes after rotating clockwise, it will stop and make a turn anticlockwise and stop. Observing the transport, when pressing PLAY, the swing arm will remain in the innermost position, not moving out of it to search and read TOC. When I press PLAY and move the laser a centimeter from the innermost position, it will begin searching, read the TOC and begin playing. The red laser light and lens movement can be observed.
Further observations and measured data:
Mechanical
- when powered off, the swing arm moves freely and will bounce once or twice when flicked with finger but it prefers returning to innermost position (flex cables)
- no dents or resistance can be felt when moving the swing arm with finger
- in service mode, step 1, the swing arm will not stay in middle position but will return to innermost position despite the offset compensation (-90mV in service mode, step 1)
- when going through service mode steps, swing arm moves faster to inner positions and slower to outside
- when moving to innermost position, swing arm often hits the end with a silent “clank!"
Electrical
- with no CD, offset of the radial motor is around zero V
- with CD inserted, offset of the radial motor is around 500mV in STOP
- in service mode, step 1, radial motor offset is set to -90mV to compensate for flex cable resistance (100mV is recommended maximum)
- swing arm voltages in service mode are symmetrical for same in and out deflections (minus the 90mV offset)
- focus motor voltage is within +/-50mV range in PLAY
- laser voltage is set to 200mV RMS
- focus amplifier is not hot to touch
Thank you in advance for your help.
Mechanical
Electrical
First change all the capacitors and dont forget the 5x 33 uF under the transport. After 35 years they are not really good anymore.
Then adjust the forcus by adjusting the turntable height by the big black Torx screw under the turntable motor
Hi PAM and thanks for your response. I forgot to mention that the player was entirely recapped in 2013, including the capacitors on the transport. I also tried to correct the spindle height, first by a quarter and then by a half turn clockwise (upwards) but to no avail. Perhaps I should tr in the other direction.
HI Willi Studer I have exactly the same problem with my B226. It does not read the TOC except when I genlty move the laser arm, did you finally found a solution ? THX
I partially disassembled the transport and lubricated it. First I pulled out the spindle motor shaft, washed it and lubricated with Isoflex PDP-65 before putting it back. To do the same with the swing arm shaft, you do not need to pull it out entirely. Loosen it so that it can pop up on top, allowing to lubricate top bearing and the shaft. Then do the same with the lower bearing.
Inn order to prevent the correct geometry of the swing arm, do not loosen or move the shin with two hex screws on the bottom, just the bolt on the shaft itself.
The CDM-1 in my player has a strange behavior. Sometimes it plays the whole CD fine. But on occassion, it jumps back to the beginning of the track being played. Could it be a mechanical issue? I am afraid of a more difficult to repair issue in the servo control.
I already lubricated the swingarm bearings as Willi described above. The swingarm moves freely and it bounces back and forth several times in power off. Could it be too loose?
I did the lubrification like you did, and it works perfectly! THXI partially disassembled the transport and lubricated it. First I pulled out the spindle motor shaft, washed it and lubricated with Isoflex PDP-65 before putting it back. To do the same with the swing arm shaft, you do not need to pull it out entirely. Loosen it so that it can pop up on top, allowing to lubricate top bearing and the shaft. Then do the same with the lower bearing.
- Digital Source
- Revox B226 (CDM-1) stopped working
