For those who need help with repairs, please use your (unused) sig line to list the equipment you have, including the 12v power supply (or other supplies), multimeter, note whether you have a scope or not (scope make/model if you have one), even the soldering iron, hot air station...
All of this helps those who can help to determine what you can and cannot do without having to ask what equipment you have.
If you have a piece of test equipment go down (like your scope), make a note as to whether it's going to be repaired or replaced.
Perry, I can not send you a direct message... So I will attempt it here.. Do you have a the schematic to the ppi pc 21400.2? I will buy a copy.. thats not an issue... What is in issue is: I think my comparator circuit isn't functioning and my power supply is running extremely high (voltage wise). I had someone give me copy or something close to a PC2350... but I have no clue where that is...
http://www.bcae1.com/temp/PC2350_1.zip
The signature line is at the bottom of each post. You get to it via USER CP >> EDIT SIGNATURE.
Yay for Perry.....
Awesome thanks... I think you might be who I got that from before..
I had changed the fets in the power supply and I remember cooking caps and I think the 15 volts fets were getting crazy hot... who knows...
I better get after it....
Thank you very much...
