Bias on Parasound HCA-806A
The resistors ended up being the round cement type and almost all were hovering around 10-15 but one was way up at 54 so glad I checked. I check this every time I get a new amp since pots/components can drift over time.
Just biased it around 18 mV. Incredible improvement resolution of hi-mids and hi-s!!! Temp on radiators is quiet comfortable. I'm impressed!!!!
I have the lid off of my HCA-806 and would also like to check the bias......apparently there is no adjustment for DC offset....
Can someone point out what resistor(s) I need to put voltmeter across from iaspire's schematic in post #5 above?
Not clear on which resistors are emitter resistors...
Thanks!!
Ok..bias adjustment done.....
A couple of channels were down around 5-6mv.......Others were around 12mv
I attempted to adjust everything to 15mv or so and here's how it ended up:
Channels 5 and 6 had quite close matching voltage drop across each .33R resistor (less than .5mv)
Channel 4 had a 1.3mv spread from highest to lowest voltage drop
Channel 2 had a 1.5mv spread from highest to lowest voltage drop
Channel 3 had a 4.1mv spread from highest to lowest voltage drop
Chanel 1 had a 4.6mv spread from highest to lowest voltage drop
Since for each channel 1 pot affects 4 output FETs.....is this just an indication of how well the FETs are matched?? just curious.....
