Unknown AKG capsule (diy mic help)
Hi, guys.
I found this capsule on line, but there's no info at all. It's akg ck40. It's 15mm x 6mm in diameter.
I already built a mic based on schoeps circuit (Zapnspark version) and i used J305 fet...it works ok, except a huge high frequencies boost. I will post images of disassembled capsule.
I tried to lower high frequencies by soldering 6.2nf or so...in parallel with drain resistor. It helped, but it needs more taming.
My question is...do i need to build a circuit with polarization voltage for the capsule...Would that help...and is this electret or condenser type?
Thanks.
use of AKG CK80 capsules
Hi Folks,
I'm at the absolute beginning here... so please take that into consideration 🙂
I see a lot of inexpensive AKG capsules on EBay. They never come with the base. I have looked at the documentation around these modules... they seem to be quite simple in terms of mute/LED etc... but my question is... Can these be adapted to an XLR base with little/no circuitry? I understand that they need a phantom power supply.
Any suggestions would be appreciated. I'm looking for a reasonable quality out-of-frame shotgun microphone for recorded powerpoint presentations.
Thanks again,
Doug
