Unknown transistor
After no results on a Google´s search, I´m asking if someone know about this transistor.
Tks MarcelvdG,
Actually it was placed in a VBE multiplier of an old SAE 2200 amp.
It seems to be not the original device there. I replaced it with a more adequate transistor to that function. It seems someone replaced it with the first available transistor on the bench.
I was just curious.
Best regards,
You could probably tell more than any of us can - at least you could test one and see if it’s NPN or PNP and what the gain is. Beyond that there is very little one could tell from that part #. Those are the kind of transistors you use where any old transistor will do.
