dual coil choke
i beg you pardon for my ignorance , fortunately i have a second choke left from you 🙂
This would defeat the purpose
to be more precise do you mean that with my actual use i don't have a real 20H filter in my power supply or the left chanel can interact with the right chanel ?
Hi!
When you use only one of the two coils you get a quarter of the inductance, so on your case 10Hy. If you use one coil on the left channel and the other on the right, you will probably still get decent filtering, but the two coils are coupled like primary and secondary on a transformer (albeit in this case probably a rather poor coupling)
Thomas
[/URL][/IMG]
2 coil chock project
If they are wound around the same core, they are not "loosely" coupled at all but **tightly** coupled.
Besides, as JonSnell said they *are* a transformer, and all ripple on the first half of the LCLC filter will be transferred to the second half, don't think you like that.
You really need 2 separate chokes.
hi , it"s not exactly that , i use one choke for the first L of my LCLC and the dual coil of the second dual coil choke split in two for left and right channel 🙂 it works fine but not at it should be referring to thomas opinion.
Hi!
Thomas
Hi, I should add that I have used the separate windings for right and left channel filtering, keeping care to make sure the phase is correct. It has worked well.
I only do it for filtering, as the last choke in an LCLC chain (or LCLCLC chain if you wish). It definitely IS important to wire it in correct phase.
I have had no issues doing this. My old o'scope shows nothing strange as compared to two separate chokes, and it saves space too... The sound is sublime...🙄
Yes, I agree they are "connected" since they share the same core material and are close to one another. However the windings are not intertwined.
Ian
Hi!
If you use the two coils for left and right, you would probably be better off using the choke as intended in series connection and in common for both channels. This will give 4 times the inductance. Since the two coils are coupled the intention of having a separate independent left and right LC segment is definitely not met.
Thomas
Hi!
Thomas
I think we are talking about two different things...
Let me take the example of a Lundahl LL1638/8H
There are two 4H windings (connections 6+4, and 1+3). In series they are 8H. in parallel they are 2H.
But that is not what I am doing. I use them separately (yet in phase). Each winding is still 4H. In series, they are 8Hy which is more filtering than I need, but more importantly, results in greater serial resistance which I don't want.
I have had no problems with using Lundahl chokes like this, all my measurements are VERY good (as compared to separate chokes - even discrete channel to channel tests) and match my simulations VERY closely. No resitors in the power supply, which has super low serial resistance. The sound is of course sublime....
Anyway...:hohoho:
Sorry, Thomas has this exactly right and you need to take another look at how mutually coupled windings work. It is a transformer for anything that gets past the last capacitors in the filter network.. i.e, LF stuff, and you are throwing away 75% of available inductance that would otherwise be available. It's a compromise ultimately in low frequency isolation between channels and in potential rippled reduction - worst really of both worlds. One of those issues can be mitigated by doing what he suggests (both windings in series).
