6X4 Tube Rectifier Bridge
Say I have a hybrid bridge built from two 6X4 / EZ90 / 6Ц4П tubes in the positive leg and two sand diodes in the negative.
Does this setup double the rectified current allowance from 70mA to 140mA ?
I expect some 100mA in my application.
greatz rectifier...
the additional diodes does not double the current that the 6X4 can supply, look at the data sheets for the 6X4....
astouffer,
and . .
tonimxp,
The resistor, R1, is there to limit the peak cathode current of the 6X4 cathode. The peak current happens each and every alternation of the high voltage secondary (positive alternations, and negative alternations). 2 alternations per power mains cycle, 50Hz = 100 alternations, 60Hz = 120 alternations.
The amount of the total series resistance that a 6X4 requires is dependent on 4 things:
Note: DCR = DC Resistance of transformer winding(s)
1. The DCR of the power transformer primary DCRpri.
Multiply DCRpri X (the step-up turns ratio of the primary to the secondary).
Example: Primary is 120V, secondary is 360V, so the step up ratio is 3 X.
Suppose the primary DCR is 10 Ohms.
The effective DCR of the primary is 10 X 3 = 30 Ohms (30 Ohms is reflected "in series" with the DCR of the secondary).
2. The DCR of the power transformer secondary, DCRsec.
Suppose that is 100 Ohms.
3. The resistance of R1.
4. The number of uF of the first filter capacitor(s), C1 and C2 on the schematic,
The higher the number of uF, the more likely a resistance, R1 is needed).
The required total series resistance, is according to applied voltage, and uF of the first cap; should be in the detailed 6X4 data sheets.
DCRpri x step up ratio; DCRsec, and Rl resistance according to:
A. The secondary voltage,
and
B. The number of uF of C1 (C2 for the other tube).
Suppose R1 is set to 50 Ohms.
We have 30 + 100 + 50 Ohms total resistance (180 Ohms) to limit the peak cathode current into the input filter cap, C1.
If the data sheet called for 150 Ohms with the uF of C1, we are good.
