Magnequest 2 EXO-050 SINGLE-ENDED PARALLEL FEED including BAC 100 Plate chokes $325
2 EXO-050 SINGLE-ENDED PARALLEL FEED (PARAFEED) OUTPUT TRANSFORMER NICKEL LAMS
Plus 2 Magnequest BAC-100 Plate chokes
These are around 10 years old.
Used only one in a mono amp. Insulated the covers on this one, grounding them for lower noise.
The other is unused.
Nickle lams
Retails for $325 ea
ALL yours for $325 plus ship
by Paypal only
Magnequest Products - MQ Iron Listing/Pricing
Special made. 100MA
Top cover is drilled out on one because of chassis wiring layout. Used. Covers are isolated from core and bolts too for lower noise floor. Ground at star ground, isolate choke off metal chassis with plastic bolts.
One in unopened plastic is unused.
[/IMG]
