carver Ct-26V Help
Dear all,
I have a Carver CT-26v A/V premaplifier/tuner that I bought in a broken state. Problem was in two burned/blown resistors with signs on the board R905 and R906 the value of which could not read nor measured and I put two pieces of 2 KOhm. I Please Carver fans to help me with this problem or send a diagram scheme (service manual) of this preamp.
Another problem of the same preamp is that by increasing the treble potentiometer does not have enough treble and also increasing bass potentiometer has a filthy muddy bass. Please help me in solving this problem.
This is a part of the scheme which I read/registered from printed circuit board and by the way measured voltages:
HI Guys,
If I had a manual or schematic for these I could help you out. I don't.
Don't buy broken things that are bound to get complicated. Check for manuals first before you buy. It looks like you are going to have to purchase a manual fellas.
-Chris
