sir 1n4007
khalsa i dont think so in4007 is substitute for her204.
her204 50ns 2a, in4007 1a and lot of difference.
is this amplifier actually working ????
----can anyone expect 25amps per rail to pass from such a thin trace ( from fuse holder to the input pin ? )
---- 16 outputs will work without base resistors ?? if so this something i see for the first time ....
---- then again when you built such a big amp distributing the outputs full pcb size from side to side ...to gain space between transistors is the best way to go so heatsink may be able to dissipate heat better and faster ....
there is a few other things ....
+1
Copper braid or copper straps jumpers should be used. The picture shows how Ecler solved this problem in their powerful amps like PAM4100 and PAM6100. The pcb shown is actually from PAM360 but the same solution is used in PAM4100/6100 models. 😉
hi nazirdigi, how is your chestap amp, did you made it?
regards,
Marjohn
not yet.
Hi,this amp is the same scheme.
Ausgangsleistung (8 Ohm): 2 x 400 Watt RMSwhat is the power of this amp?
Ausgangsleistung (4 Ohm): 2 x 700 Watt RMS
Ausgangsleistung (2 Ohm): 2 x 1000 Watt RMS
Ausgangsleistung (8 Ohm gebrückt): 1250 Watt RMS
Ausgangsleistung (4 Ohm gebrückt): 1700 Watt RMS
Ausgangs Schaltungstype: Class AB
Eingangs Impedanz: 10 kOhm
Frequenzgang: 15 Hz - 25 kHz
THD: < 0,03%
IMD 60 Hz & 7 KHz, 4:1: < 0,038
Anstiegszeit / -geschwindigkeit: 40 V / µsec
Signalrauschabstand: > 102 dB
Dämpfungsfaktor: > 400
Kühlung: Aktiv, Temperaturgeregelt
Schutzschaltungen: DC-Ausgang Schutz, Langzeit Überhitzungskontrolle, Einschaltverzögerung, Soft-Power-Start, intelligenter Überlastungsschutz, Clip Limiter
2 x XLR Eingang + 2 x XLR Thru Ausgang
2 x Speaker (SPK) Ausgänge
2 Kanal Lautsprecher- Schraubklemmen
Parallel / Stereo / Bridge - Mode
Normal / Compress - Mode (Clip Limiter)
Ground / Lift- Mode
Sensitivity-Schalter: 1,44V / 1,0V / 0,7V
elektrischer Anschluss: 230 Volt
Größe (LxHxT): 482 x 383 x 88,8 mm
Gewicht (Netto): 16,5 kg
Gewicht (Brutto): 18 kg
- Cheshtap Power Amp
