SAE T101 Tuner Questions
Hi Everybody! I am new here. I just purchased a very clean used T101 Tuner. I am looking for a users manual as I don't know how to use all the features. Can anybody help with a copy? Also, the AM tunes in the wrong increments. I had the same problem on a shortwave portable but realized there was an external switch to change it to the correct spacing. Is there something on this radio that changes the spacing for the USA?
Thanks,
Bob
Must be a rare bird, it's not even listed on TIC. The rat's nest of wires inside seriously rivals some Japanese tuners.
I would go through the ICs and identify good candidates for a discriminator. Once found, check output level and DC - the tuner may be in off-channel muting if alignment has drifted substantially.
