linaeum tweeters ET-6A
i have just now recieved a pair of these and am intent on making a pair of bookshelf spkers using them, however i have been unable to find ANY specifications online and aurasound have been unable to help.
has anyone here had any expereince with them and any info they could give me on their specifications???
There was a review of the Radio Shack use of the tweeter
several years ago.
Stereophile Review of Radio Shack speaker
From the review:
while a 6.2µF plastic-film series capacitor keeps LF from the tweeter.
Description: Two-way, stand- or bookshelf-mounted, reflex-loaded box loudspeaker. Drive-units: 5" polypropylene-cone bass/midrange; 2" by 4" Linaeum dipole tweeter. Measured crossover frequency: 4–5kHz. Frequency range: 85Hz–20kHz (no limits given). Measured sensitivity: 81.5dB/2.83V/m (B-weighted). Nominal impedance: 8 ohms. Amplifier requirements: 100W recommended maximum.
The Linaeum tweeter comes in sharply above 2kHz, but on-axis at least, its output is down in level and looks very ragged.
That might give you a starting point.
unfortunity the tweeters i have are aurasounds later version, 6 ohm and, err thats everything i have on them right now, unless i get some help i guess my only way forward is to get them measured (and no i really dont want to have to do this)
Optimus Dipole Tweeter
(400-1389) Specifications Faxback Doc. # 34989
Magnet Weight: ........................................... 2.8 oz (79.2 g)
Speaker Weight: .......................................... 14.8 oz (420 g)
Power Handling: ........................................... 50 Watts (RMS)
Maximum Power: ................................................. 100 Watts
Impedance: .............................................. 8 Ohms (Nominal)
Freq. Response: ........................................ 2,500 Hz - 25 kHz
Crossover Frequency: ............................................. 2.5 kHz
Capacitor Type: .............................. Bipolar Electrolytic 4.7 uF
(YO/EB 11/1/96)
thank you for your help, alas the driver i have is the aurasound et-6.
i have contacted wilmslow audio who will measure one driver and provide all the measurements.
anyone searching for these specs can email me and i will provide them, i will also try and get them hosted online and i shall provide a link later if iam succesful.
samuelduncan1983@hotmail.com
SGD, did you ever get specs? I know this thread is over a decade old, but I found a MINT pair of RCA 40-5037 speakers in a thrift shop, for a sawbuck. I want to scab the tweeters, and add them to a 6" TL I have on my drawing board. I'd take any info you have for them.
