Simple question
Is there any rule that says that in bi wiring the cables MUST be of the same type and why ?
Pros cons do and don't please .
I used to have kimber 16 TC in a system that own and know 6 years . thought it was fine, in general I like twisted or braided things ....for speakers .
So a friend was busting my @@ to try 1mm single core pure copper cables slightly twisted
He was right !!!! after that I rediscover my speaker both in middle and high ( can write specific details let's stay that I loved it ) BUT I lost 50% of the bass ....almost
So I expirament try a few things like other type thicker or not twisted or double lines with minor improvement ....
So come up with the idea to biwire use previous kimber for bass and single core for middle and high ..
To my ears is like I have a new speaker never heard my speaker playing like that .
BUT !!!!!
My audiophile friend says that you cannot biwire with different types of cable ..
Can anybody explain why ?
BUT !!!!!
Bi-wiring is effectively a form of star grounding based at the amplifier output, although there is little potential for gains in that area. From a certain point of view it could be said to be more than that, and why should there be a limit on which cables to use? They operate independently.
Placed my question with manufacturers that produce ready cables for bi wiring and they said to me that HI level cable is different material diggerent structure
So i done see any reason to MUST have the same type
One audiophile said to me that signal travles different between different types of cable and indeed is effected differntly by the skin effect , inductunce and capacitalce of each individual cable
that may result to a minor phase shift between the 2 ways low/and mid hi
This on its own must be a very good reason
in my case all that worked for my favor and to my ears i now have a new speaker in my house
next week i will modify and share the same practice to my second set of speakers to see how things are going to be
If you like your 1mm solidcore for mids and treble, why not make 2mm solidcore for bass?
There are no general rules. If your ears say its good, then it´s good.
All the best
Mattes
All the best
Mattes
There is 2 important rules in the world of hifi, the first one is money and the second one I can't remember.
Because all possible combinations i tryied it appears that they cant produce enough bassHi,
All the best
Mattes
the shine but only in mid and high frequencies
verified that with other users also
Oh, this can be a good one. Discussing bi-wiring pros and cons with Hifi-people is like discussing engine oil with car guys.
This thread can explode...bringing out the popcorn!
@Mattes above universally sums it up.
But some tinder to get the fire starting - by definition bi-wire implicate different loads are presented for each wire set. In that perspective whichever combination of cables you chose is completely overshadowed by the load each node sees and has to transfer signal through.
And remember, almost everything you change make a difference in sounds. If it sounds good, it is good.
In most cases:
The only thing that matters in speaker cables.
Is the total end-to-end resistance of the cable with respect to the loudspeaker frequency impedance curve.
In bi-wiring you can literally use any wires you please, either the same or different.
Besides the resistance, the inductance of the wire does also matter (LPF).
For unusual wires (Kimber Cable, etc.), the capacitance also matters, and can affect the amplifier.
In most cases:
No this is absolutely wrong and clearly very outdated informationIn most cases:
Each cable will introduce capacitance , inductance and skin effect in the signal . Resistance which is the less importand and indeed each cable in biwiring will behave different simply because they have different load .
We all wished that the only problems of cables was resistance This will only effect sound level only
In biwiring either with the same cables or with different cables one will face for both cables capacitance , inductunce, resistance , structure problems which result to some interference issues .
As a result even with same type cable be wiring we should expect the cables to behave slightly different because one way or another those handle different loads .
In case where my cables have haotic differece in construction one is multicore braided almost 6mm, while the highs are single core 1mm slightly twisted obviously there should be a huge difference in they way the work .
To my ears it seems that they effected phase to a slight point.
Capacitance, inductunse , resistance , and skin effect will eventually effect the speed the signal travels and between two so different cables any losses will be totaly different and that is what we hear as difference between the solution A next to B
Accordingly if you have a speaker that is perfectly phase alligned ( which i see almost impossible for passive speakers ) there is a cahnce that different ypes of cables will mess it up
In my case it worked for the best ( i can accept that my speaker was not perfectly phase alligned ) and i was just lucky
Indeed though i will perform the same test with the same principal with a pair of random speakers that i have avaiable .
About twenty years ago (time is a speedster...🙁) I heard of a University of Patras publication, where while Biwiring was not proven to be advantageous, a three-wire connection with one common "ground" wire to the crossover, but different ones for Hi and Lo frequencies was proven to be . . .
Active systems play with electronic xovers and when they need to change something they tweak the electronics not the speakers or xoversbi-wiring??? dont wait another 40 years to move up to active systems.
First this cannot and will not be ever diy
Second and most impotant signal has to much processing that we dont like
Even a DCX 2496 offers so many options about time alignment and phase control with only 300something euro
But can it play in a hiend system ?
no way Jose
@toulou
Fellow Greek ....
In Greece there is lot of work done look at Signal Projects Mr Korakakis , Look At IDEON audio and also check mamalos.com
Mr Mamalos allready hold 5-6 patents on audio cables and his work only make Physics profesors to redifine physics lately . Check his web he explains some interesting things about the principal of operation .
So outdated opinions about resistance in cables ( speakers or Line ) and use of extreme material like pure copper silver or even gold are now forgoten an techs now look to other things like capacitance , inductance , skin effect (for audio freq ) .
Again in the past one electronics engineer will measure capacitance , take the calculator , calculate the filter that is formed by the capacitance only to understand that center frequency is way out the acoustic signal ( most of times ) .
So what makes audio cables behave so different one next to another ?
One reason is that in general capacitance inductunce and resistance ( if any) stand against signal transfer no matter if the filter frequency is too high .
The other is that most amplifiers have feedback circuits ( most in class Ab which is most common)
so minor changes that take place there because of the cable behaviour eventualy might have a huge impact due to feedback .
kenwood in the past had an idea for a Σ drive circuit which actually takes feedback from the binding post of the speaker to elimenate cable issues
In theory is a good idea never tested by me though
kindest regards
Sakis
Fellow Greek ....
kindest regards
Sakis
Many have tried and liked using a moderate value termination resistor at the speaker end, around 100R.
I'm curious about the 1mm solid core cables, what is the spacing, are they just twisted together, or are they like DNM Reason?
Perhaps use multiple runs of solid core to the bass, or litz cable (use cat5 ?). I think some people use 1/2 bi-wireing, a single cable to both positives, and separate cables from the negatives, but I forget the reasoning. If you used copper tube wouldn't that have the skin effect of thin solid core, but the cross section suitable for bass? Just a bit stiff.
Active systems .......... cannot and will not be ever diy
Active systems .............. has to much processing that we dont like
@east electronics
The paper I mentioned in #14 was brought up in a conversation, but I never read it.
Anyway, I think that if an exact common zero-reference for all the sections of a crossover is considered important, the use of a single cable leading right inside the speaker makes sense: Why place this zero-reference two+ meters away inside the amplifier, connected via separate cables to the different crossover sections?
- Speaker cables (biwiring)
