Carver M1.0t - wish I hadn't bought it.
So I have a story. Many years ago I had a Kenwood KA3500 integrated amp and enjoyed it for about 10 years. For some reason I decided I needed more power and read a Stereophile Article that favorably compared a Carver amp against a very expensive tube amp. After reading the article I decided to buy the amp on Sterophile's review and it was also on their list of recommended components. I hooked it up and listened and was sort of disappointed. Especially with the bass (a little flabby). Then I decided that because I was using the preamp output from the Kenwood, I needed a dedicated preamp. SO I bought a Rotel preamp. I don't remember hearing much difference. I know this isn't exactly DIY, but I am just curious if anyone else has had a similar experience. It was a rather expensive lesson. (buying something based on a review in a magazine).
I have DIY speakers now but had Bose 901s in the 80s and 90s. Bass wasn't flabby with the Kenwood amp but was with the Carver amp. Both were solid state. Kenwood was 40 watts and Carver was 200+ watts. Everything is gone now, got rid of it.
The last time that amp was produced was in the 1990s. I looked up the old "Carver challenge" Stereophile review and that was from 1985! For its time the amp was good and produced plenty of power - I owned on back in the 1990s - but these days there are much better options. Your M1.0t likely needs a tune up and service just to perform anywhere near as good as it did when new, so be prepared to invest in that. It is the case for pretty much any electronic equipment that is getting old and parts are likely past end of life. This might explain your complaints about "flabby" bass. But IIRC even a new M1.0-t had the reputation of rather "lean" or "weak" bass reproduction.
FYI recently there was a review on the M1.5t (the higher power version of the M1.0-t) over at audiosciencereview.com that you might read through and then decide if it is really worth it to continue:
https://www.audiosciencereview.com/forum/index.php?threads/carver-m-1-5t-review-vintage-amp.30983/
Conclusions
It is nice to test products that were iconic during my youth with state of the art measurements that didn't even exist then. Using that, we see that in noise and distortion the M-1.5t is outgunned by vast number of amplifiers today. However, it produces copious amount of power which would have been even more impressive then.
There are techs who offer full service for the M1.0-t on Ebay that you might want to seek out.
Actually, Stereophile article ("The Carver challenge") from 1985 was about the specially modified prototype of Carver M1.0 - they couldn't tell the difference between the sound of this solid-state amplifier and the all-tube Conrad-Johnson Premier Five amp. After that, Carver M1.0t ("t' for "Transfer function") was marketed as "identical to the challenge winner". But it was not identical, according to Stereophile measurements of Carver M1.0t amp in 1987.
However, Carver proved his point - it is possible to build a solid-state amplifier with the sound identical to any tube amplifier.
Reactions: DIYPDMOUT
Yes I had a reprint of the Stereophile article and that was the main reason I bought it. I thought hey I can get a 5000 dollar tube amp sound for (I think) what was about 600 dollars. Anyway it was a lesson learned. Carver also tried to do an Apogee Speaker on the cheap which I heard didn't sound anything like an Apogee, but resembled it. That Carver amp brings me back to the point of doing a DIY amp. Solid build practices, quality parts and rock solid linear power supply and I probably can't go wrong. And if something goes wrong I built it and know how to fix it. Not to mention the savings$$$$.
I remember that amp, which did not impress me. The bass wasn't exactly anemic but it also wasn't compelling. Indeed, the amp was rather two-dimensional. I did fall prey to Bob Carver's marketing hype (that he could design and sell components at a fraction of the cost of comparably-sounding competitive units) by buying his TX-11 tuner sometime in the mid-80's. That honeymoon lasted maybe a week before I realized I'd been duped -- the Carver TX-11 tuner sounded awful. I sold it soon afterwards at a loss and saved up to buy a Magnum Dynalab FT-101, a vastly superior product.
Maybe Carver has had some great-sounding products over the years. Maybe. But I haven't heard them.
Regards.
Solution is easy. Advertise it and sell it. Buy/build a better device. Solved.
Timing is essential, it works best to do so days/weeks and maximum a few months from buying the device as it still has reasonably high value. Keeping and using such a device for years is sadomasochism.
If memory serves me there is a large resistor in series with the output to mimic the output Z of a tube amp.Remove the resistor,short it, and the bass response with improve somewhat..Cheers.
Only somewhat. It still has the most anemic power supply in its class - the weird power transformer and control circuit, little bitty reservoir caps run right at their voltage rating. Junk power transistors with squat for gain. 24 gauge wire for the power and speaker connections. Looks like a damn boom box inside. Phase Linears were better. Yeah, there is nothing inherently wrong with H-class amplifiers but there is such a thing as taking it too far.
I agree with JP - if you don’t like it sell it. There are people that will buy them.
I was just posting a story from my past. Amp is long gone -- sold 20 years ago. As far as Carver products -- My guess is that his engineering unit had the desired sonic characteristics but the production versions had some corners cut to hit a price point. Another part of the story is that I listened to a friend's set up which was 2 Macintosh tube mono blocks at 20 watts per channel and I heard what bass should sound like. Much better than the Carver even though the Carver was supposed to have 10 times the power. Carver has been in the business a long long time, so I am sure he has some good products, I just don't think the M1.0t was one of them.
Oh then it is OK. I think many of us have disappointing experiences with some brands/types. In my case I receive new devices every few weeks and most of the stuff also leaves within 2 weeks 🙂 Benefit is that one does not get attached to any brand but give more attention on type number and IMHO that is quite good. The thing that a brand stood for a certain high quality is almost gone. Brand awareness or how it is called is an invention of clever marketing people just to get your money. Today brand A can produce both a wonderful streamer and a mediocre amplifier at the same time. It is not my cup of tea to run after brands/designers and think all they introduce is the best thing since sliced bread. That is "pushed assumption". Some even wear clothing with the brand advertised on it which seems pathetic.
Add the recent mediocre Far East quality of things with the nice known brand logo on it to that. Everything is replaceable and the device that does not perform optimally in your home may be liked by someone else. It may not be the most green solution but since the devices are produced anyway.... In the forest of mediocre devices some flowers stand out however, those are the flowers we look for.
I have an original KA-3500. Bought it in 1976. With the matching KT-5300 tuner.
It doesn't have a preamp output.
BTW, mine was fully rebuilt three years ago, it may have only a 40 watt rating but it has a heavy power supply...
Reactions: Halauhula
...I decided to buy the [Carver M1.0t] on Sterophile's review and it was also on their list of recommended components. I hooked it up and listened and was sort of disappointed. Especially with the bass (a little flabby).
As I was driving a pair of the ubiquitous Cerwin Vega flagship D9s (the existing family room speakers), there was no lacking in low-end, but there was a lacking in my own "ear". Only once I purchased my first quality speakers in a set of 2-way B&Ws DM560s from The Audible Difference in SF did I notice a slight "sluggishness" (?) in the lower frequencies. I was a junior in high school on very limited budget, so it was as much as I could stretch at the time, but I really fell in love with the DM560s over the years, and swapped all the internal wiring with 10awg OFC. It sounded great, but I always felt it could be a bit better, since swapping several amps with friends, there was something a little off about the lows. One day I was lucky enough to stumble across as set of Acoustat 2+2s electrostatics with Medallion Blue transformer upgrades for a great deal, and that's when the low frequency lackluster started to get to me.
About a year later while perusing the Diablo Dealer (free classified here in the sf bay) I found an M1.0t for sale at a great price and decided to try dual-mono with them, and wow did they come alive. Presenting half the impedance to each channel I suspect is what did the trick (along with infinite separation) because it was as if I had bought an entirely different amp setup.
Only later when a friend with a pair of Acoustat Model 2's (essentially 1/2 of my 2+2 setup) scored a pair of BEL 1001s and offered me his pair of Carver Silver 7t's for a decent price, did I feel I had finally found a worthy upgrade to the dual-mono M1.0t's and I'm still rockin' the Silver-7t's today.
My setup is a pair of Acoustat 1+1's driven each by a Silver-7t sitting directly on top of the MK121 Medallion Red transformers (while my 2+2's are in storage since they don't fit in my space rn). This made a big difference, and I can only speculate keeping the resistance, capacitance, and inductance to an absolute minimum to the speaker voltage transformers was partly reason for the slight improvement over longer speaker wires, but the 7t's now sound as good as they can. These are fed via 20' Blue Jeans LC-1 interconnects from a Carver C-1 normalized to 12-o'clock volume when used with the upstream surround receiver, and used for regular volume control when listening to 2-channel audio from my custom RaspberryPi streamer I built with a simple web front end running nginx feeding an S.M.L.S. SU-1 dac into the C-1. But I want to get something more robust, as the library I was using to access Spotify stopped working due to Spotify countermeasures.
Back to the M1.0t... the slew rate is excellent on it since the higher frequencies and timing were always outstanding, even in stereo, but I can only imagine that the class-G style rail switching that Bob Carver implemented in this amp somehow doesn't work as well at the lower frequencies unless both channels are subjected to the identical impedance loading characteristics (as when ran in bridged mode) as they run inverted to each other, similar to many car audio designs. Regardless the reason, it's was a truly breathtaking upgrade going dual-mono M1.0t's and only bested by the Silver-7t's with their different op-amp characteristics. Unfortunately it's only magical for the single listener in the sweet spot, since moving just a few inches either direction turns into a mess, which is the downside of infinite baffle planars. Still fine for surround sound as people are always impressed.
The DM560s are still holding great mounted high, serving as surrounds, now each normally being driven by 1/2 of one of the M1.0t's (but currently on the surround rx amps due to the one M1.0t needing repair). ELAC Debut A4.2 rears are each being driven by the Onkyo TX-RZ900 built in 7 channel 200W/ch amp as well with only 2 channels normally used (tho currently 4 with the surrounds). The center is driven by the other M1.0t bridged to mono. Surround sound is really just for impact and entertainment fun, and I've never seen the point of multi-channel "audiophile" setup so for me this works great, plus turns the room into a 4-corner-sound dance party when desired since the DM560s can really belt out the db's when necessary (compared to the electrostatics).
At some point I found a Sunfire True MKII on craigslist which I had the amp plate rebuilt by Bill Flannery back when he was still doing Sunfire repair work (and since I didn't have time) so that's helping extend everything down below 70hz.
The one M1.0t that has died needs repair so I plan to source the parts to do the M1.0t "mkII opt002" mods to each of mine when I get around to fixing it, since I'm sure the capacitors in both are surely getting leaky and not able to hold up the power they were once capable of and the op-amp swap I hope will bring them closer to parity with the 7t's.
TL;DR: the M1.0t's really shine when in a bridged dual mono config
We now return you to your regularly scheduled diyAudio content, already in progress...
-=dave
Hi Dave,
Those amplifiers are designed to drive full range or lows only. Bridged is never as good as stereo mode (offered as a marketing department things on all amplifiers). You shouldn't "upgrade" them, but okay. There are things that can be done to improve them, most internet stars get it wrong.
The best Carver amplifiers were the TFM-75, and the Lightstar series one.
I was Canadian Factory Warranty for Carver.
