Nice Big Power Meters like the Manufactures Use???
When I wanted some modicum of accuracy I bought from RAM Meters. I do not see anything except white faces though. For a classic look, I searched on EBAY until I found a pair of vintage meters. For My last build I bought those cheap meters from Ebay and added the LEDs - not loving them but adequate I guess.
Cheap-n-Cheerful S0-45
Ram Meters
Vintage Simpson
Those round meters are 50 cents each here.
Look for 0-10V log scale meters, they work same as VU meters.
Use moving iron type if accuracy not needed, more rugged.
And you can color print on adhesive paper to get a custom dial look, stick it over the existing dial.
rtw meters not available.
KISS....Keep It Simple, Stupid! principle here, a simple solution is getting complex.
A software base meter on the display of source (computer, laptop, cellphone, tablet etc.) can be used. Apps should be available.
Peppy meter total cost should have been indicated, though screens in small sizes are getting very cheap if they are not industrial grade.
The purpose is simply dancing needles (eye candy) or something more functional?
See sites for industrial grade meters, and change the dials, it is simple to open, and fun.
Alternate is to find old amp with working meters, use new innards, you will get a retro case as well.
Check out Chinese sites as well, there were sellers selling retro meters for tube amp builders.
Those sites are not accesible from India, and the quality of the meters is unknown.
Was told these were made during WWII. They are US made unused/surplus glass sealed airplane meters for sure (note the spelling error). Planned to use them in a class D project but got in trouble with BTL outputs.
Reactions: tonyEE
You might have to scavenge an Onkyo or Denon chassis for the look you want. I expect you want dark dials?
I thought the Carver meters looked fantastic, but that styling dominated and didn't really play along with other brands.
I have these older rebranded Honeywell meters saved for a monobloc project, but the styling of the chassis will need to match.
I've thought about getting some of the large "McIntosh" style meters from AliExpress and buying some of the following to use as a backlight. Could be striking I think?
https://ellumiglow.com/collections/el-panels
Those are beautiful.... Loving that ON/OFF switch with the red guard on it. Fantastic paint job.
Meters, switches, knobs, Bakelite, crinkle paint, tubes, transformers, cables, wires...
I believe The Enemies Of Earth used equipment like that to communicate with Ming Of Mars.
They got these on eBay
https://www.ebay.com/itm/365472219637?_trkparms=amclksrc=ITM&aid=1110006&algo=HOMESPLICE.SIM&ao=1&asc=285109,285767,285774,285930&meid=5e098a45f5b04b5c9755eaca270a72d4&pid=101875&rk=4&rkt=4&sd=365472233896&itm=365472219637&pmt=1&noa=0&pg=2332490&algv=SimVIDwebV3WithCPCExpansionEmbeddingSearchQuerySemanticBroadMatchSingularityRecallReplaceKnnV4WithVectorDbNsOptHotPlRecallCIICentroidCoviewCPCAutoVisionMM&brand=Unbranded&_trksid=p2332490.c101875.m1851&itmprp=cksum:3654722196375e098a45f5b04b5c9755eaca270a72d4|enc:AQAKAAABgO7WQzztPwW6PkgoYfQkPoIk8LPijUJeRSIaSsdtf4xtPJNwHvvrPnsdhIFEZLwP5X%2F0pqGkKRfiBPA92WLZSaWJeHJ6aHHpPmFFOZkbwiXNGDpreUeBHj2ZrDtFEH2%2BiQkXd3wmf1Lc3IzYTN6YW7me6RU%2FP2u4AIJjtMZpnUzn4fhxgZX8ivT%2BPzOsmjM85UZKRXWhewCBubf%2BsyilGjYonHE0nuzBE%2FNM2KS02bcZdma2myDCPZe2Gz%2BJ%2BU8ax5cM0%2B12A6TOJ9fn8l2Ob8tGxil%2BPcywutYgMNCxPhlUmKMLPMV%2FBN0d4lOIAy5OFHEuWAhmxUxmoWn6zClq8znj1qzVzFpoW4OohHC%2BsFWJjjGS4mH0PkdaUBSUjN1z1oBTv3cyrLrsCiV5X9VZWNZpSeOneP2Agw3bIo0RygAnhRlvJSryIaK4cGExhG6IJthigw3Yg23HUGtgAa6mshUrlMC1Tsqx%2FRUV%2Fxp0k8sEMb5dIOy8oQ9qJMf274Nq4w%3D%3D|ampid😛L_CLK|clp:2332490&itmmeta=01JV8BXA113ZRJD5SEBJAJ2JMT
