I need a pre amp for my desktop and don’t feel like building one. Any recommendations?
Because I’m not listening critically, good sound and cheap price is the goal
I used one of these for a while. Amazon also stock their simpler one.
https://www.amazon.co.uk/5-band-Preamp-Equalizer-Pre-Amplifier-Headphone/dp/B0BHYWR8KW/ref=sr_1_5
See if you can find an old BottleHead Foreplay II or III. Make sure it's got the CCS upgrade.
jeff
jeff
hi, can I ask what you need the tube preamp for?I mean for the sound.I need a pre amp for my desktop and don’t feel like building one. Any recommendations?
Looks like you already have a volume control on the amp. Is there enough gain when plugging the DAC directly into the amp?
If so, and it's very likely there is plenty of gain, then that's all you really need, unless you want tone controls, etc.
I saw this on the forum. A talented person gave this preamp design. I've never seen anything like this.
Thanks!!! I just don’t have time to build it.View attachment 1458123
Gotta cool the signal somehow. 😂😂😂He's obviously a plumber. Wonder if there's water in those pipes?
It looks like a cake.🙄
First ask yourself if you really need gain while looking at your sources and power amplifier. What do you really need? Then think you possibly need source selection and volume control but no or little gain. Also take input impedance of the power amplifier and output impedance of the sources into account. Write stuff down.I need a pre amp for my desktop and don’t feel like building one. Any recommendations?
Then go on from there.
Fonky Look ! Truly excellent... 😎 😎 😎
Obviously inspired by a two-tone '59 Chevrolet.
A preamp , to my ear, always adds dynamics I don’t hear with just an amp.Looks like you already have a volume control on the amp. Is there enough gain when plugging the DAC directly into the amp?
Added dynamics is about right as multiplying the sources output voltage with the preamps gain usually means way above normal line levels. This can be noticed at such setups with the "maximum volume at 10 o'clock" phenomenon. When having picked a wimpy preamp with worse drive capability than the sources have bass roll off may also occur. For some reason many if not most tube preamps have way too much gain and think 50 kOhm to be a heavy load. This also means (amplified) hiss/noise/hum and what not. It is a choice that will force one to non critical listening 😀
- Tubes / Valves
- What is the best cheap tube pre-amp?
