@Pano once devised a very simple test, see https://www.diyaudio.com/community/...h-voltage-power-do-your-speakers-need.204857/ You have to read the first few posts to understand what the test voltage means.
I have B&W CDM1 SE's too but can't listen to them because I get fatique from it and the Yara's are the same honestly. I have Totem mites as well and they r the only ones that don't give me listening fatigue. I was told to try a better amp before looking for more speakers.
That could be true, since electronics do have a sound of their own (especially if overdriven),
but the speakers are more likely to be the source of fatigue. Have you looked up reviews to see if they mention this?
Do you have an opinion on Class A/B vs Class D?The Moon does double power into 4 ohms, so that's good. But I can't tell you which of these would work best on your speakers.
Often people buy equipment to resell it, so they may not know that much about it, even if they have good ratings as a seller.
Okay thanks! I was looking at the previous link shared here and I think my speakers should be fine at 40W but I will do a test on the Topaz tonight to make sure.@Pano once devised a very simple test, see https://www.diyaudio.com/community/...h-voltage-power-do-your-speakers-need.204857/ You have to read the first few posts to understand what the test voltage means.
Hmm, well I guess according to this, if I like the Simaudio Moon 250i, I should go for the 220i since it would be the only amp I sort of tested out of the batch.Both types can vary a lot in different models, so it's best to hear the amp on your system.
General consensus on B&W speakers is listening fatigue haha so I just figured it might be the speakers. I found a review saying the Audio Physics Yara 2 would be just like Totem Mites but with better bass. Unfortunately in my system they sound closer to the B&Ws, just a much better soundstage illusion (which was very important to me and one of the reasons I decided to look for something to replace the B&Ws. Now I just have to get rid of the boomy bass and maybe get some better detail out of the speakers. The rest of my system is decent, I think my worst component is the amp by far. I use a SMSL C200 DAC and a clearaudio nano v2 phono stage. My turntable is a 1210 MK5 that I am very happy with, I will eventually upgrade from my Ortofon Quintet Red tho, I would like more instrument separation from a better cart.That could be true, since electronics do have a sound of their own (especially if overdriven),
The Topaz SR10 has 80 watts I believe, and I am able to crank it pretty high so I am a bit concerned I guess, I will do some testing tonight.
Most speakers can cope very well with high power peaks. The main problem is the long term power. If you are listening at room spl, you're likely stay way below half a watt. The problem is if you have a hours without end party the tweeters might not survive it. If you're planning on that, get a PA speaker.
Some people suggested that any of the listed amps would be a significant upgrade, but the the Simaudio is closer to serious gear. I never inquired about the Peachtree as I just recently found that one.
No no, I actually don't like loud music, I would like good detail from the amp without having to turn the volume up. I just play loud for very short periods of time, my room is tiny.Most speakers can cope very well with high power peaks. The main problem is the long term power. If you are listening at room spl, you're likely stay way below half a watt. The problem is if you have a hours without end party the tweeters might not survive it. If you're planning on that, get a PA speaker.
It's possible that the acoustics of your room are at least partially responsible for the fatigue.
Do you hear a lot of echo when you clap your hands sharply?
Well, a 'significant upgrade' can relate to a better SQ but can also relate to a higher spl or higher SQ on a higher spl. You have to differenciate which category you will actually benefit from, which makes each choice valid or invalid. That doesn't mean their experience isn't correct but that determines if that judgement applies to you!
That's a very good call but to draw a real live consequence from it is hardly possible. It's not wrong but you have to dig deeper than that to get to the reason why is's not sounding great.It's possible that the acoustics of your room are at least partially responsible for the fatigue.
Yes absolutely, one of my speakers is in a corner sadly. I was going to post my setup and ask for advice. I don't think there would be echo on a clap as my walls aren't smooth, they are relatively rough OSB boards that have been painted. I also have shelves, a bed, and plants that help. Here is a photo of the setup.It's possible that the acoustics of your room are at least partially responsible for the fatigue.
I think my biggest problem is that the speakers are close to the wall and when I sit at the computer the speakers are very close to my ears.That's a very good call but to draw a real live consequence from it is hardly possible. It's not wrong but you have to dig deeper than that to get to the reason why is's not sounding great.
Is SQ sonic quality? SPL is loudness right? (sorry I'm relatively new to having these sorts os speakers and amps)Well, a 'significant upgrade' can relate to a better SQ but can also relate to a higher spl or higher SQ on a higher spl. You have to differenciate which category you will actually benefit from, which makes each choice valid or invalid. That doesn't mean their experience isn't correct but that determines if that judgement applies to you!
They aren't bad but it's a typical 6"/1" speaker. Good for the money but not high end either.
The setup isn't bad. You could reduce the wall reflections but I think the main issue is you don't have any dispersion control.
Yes (to all)Is SQ sonic quality? SPL is loudness right? (sorry I'm relatively new to having these sorts os speakers and amps)
Lots of bare surfaces in there, including the floor and windows.
You may have to deal with that to help your problem.
Think about rugs and curtains to start.
Computer speakers are intended to be heard close up.
Lots of bare surfaces in there, including floor and windows.
Yes, that's the first thing you should do about the acoustics. It changes more of the sound than any other speakers will.
That's also true but you don't have to reduce your choice of speakers to that. However, there are so good cheap near field monitors out there, a DIY solution is surely possible but will not be cheaper than cheap NF monitors that are available.
- Is 40 watts per channel enough?
