Looking for high-voltage tubes
Hi Jan,
very interesting project... I also thought already about how to build such an amp... I would try a 4-125A (QB3/300). Max. plate voltage for RF power amplification should not exceed 3 kV (datasheet...), but from its construction its plate can take a lot more.... Max. screen voltage up to 600V, with such high plate potentials I would rather go quite a bit lower, 200-300V. Graphite plate and very rugged construction, so I think this would be a good beginning at least... But how do you plan to realize the plate resistances? Resistors, chokes?
In this way I also operated an EL81 with up to 1,2 kV DC plate voltage (and 70V screen) as a regulator tube for a power supply, which could be set from 800V to 1,2 kV output voltage using an EL519 as pass tube.
If it should be a triode, I would eventually try the former colour TV HV shunt regulator triodes like the PD500..... Maybe two or three of them in parallel?
all the best
Uli
@tubeampuli
Question again. If I look at say an 813, the max Va in the various modes is 2250 or 2500 V.
Yet, that is a DC spec, and if I use a SE choke loaded stage with say 2500V B+ (DC), the anode swings between close to zero and almost 5000V.
Does that then not violate the Va spec?
Jan
6HZ5 6000V 30W 300mA pk
Reactions: TonyTecson
I believe that it is to limit the Pa as they are HV regulator tubes, but there are no charts
on lower voltages.
I doubt that you cold make a wire thin enough to fuse at 1,5 or even 25ma and have it survive
as a lead in wire in a tube.
I am wondering, those HV reg tubes with Va up to 25kV with Ia(max) 1.5mA.
Would they break if Ia was 25mA peak?
Look at the heater power. 6BK4 6.3V 0.2 Amp , smaller than a 12AX7/ECC83
I have a 6BK4 here, and the cathode is miniscule.
That PD500 looks better though. 7.3V 0.3 Amp
The PL519 looks better than the 6HZ5 for continuous HV, since it has a plate cap. The Compactron socket (only) of the 6HZ5 would probably break down with continuous HV, unless you submerge the socket in silicone oil.
Reactions: decramer
