RPi+DAC+Hypex amps in one case. Who has done this?
I’m researching active crossovers for a possible future build. What I’m looking for is,
  • Raspberry Pi
  • Six+ channel DAC
  • 6x200w amps
All in one case, around the size of an AVR.
It seems doable, but my searching hasn’t provided anything. I’m just looking for ideas on cases, layout, and positioning of components. Trying to fit three Hypex amps and two power supplies while providing enough space for cooling and separation for the DSP seems tricky without getting a large case. Maybe I should befriend some engineers from Denon 😆
edit
I found this earlier in the week which got me looking for similar designs with more powerful amps.
https://www.audiosciencereview.com/...to-the-smartcross-project.47976/#post-1721601
RPi is a serious source of conducted and radiated EMI/RFI relative to the sensitivity of a dac. If put in the same case with something like a dac, its likely to couple radiated EMI/RFI noise into the dac causing some reduction in SQ. Perhaps grainy or veiled sound. Use of proper shielding between RPi, Dac, and power amp modules may be needed. Internal shield walls could affect heat transport out of the unit however.
Allo made/makes some the most noise immune dacs for RPi. They use layer(s) of copper as shielding. Also, Allo Katana dac had an optional isolator board that could go between RPi and the rest of the dac stack. It audibly helped some.
Also, that was back when RPi was at version 3, which was less of a noise emitter than RPi v4. Another thing Allo did was design USBridge Sig, with low power RPi compute module on it. That replaced RPi with an lower noise device and helped even more with the noise problems.
Some people tried replacing all RPi power supplies with linear regulators and reported some improvement with noise problems.
...Trying to fit three Hypex amps and two power supplies while providing enough space for cooling and separation for the DSP seems tricky without getting a large case...
Yes it is quite tricky, I might even say 'frustrating'. Heat of course, plus shielding/separation and decent cable routing, to avoid noise. Also it would be quite cramped to work on and so harder to assemble, debug or mend. Then if you later change your mind, or if requirements change, a singe combined unit is far less flexible than separate boxes.
In the past I've done many 'very compact' electronics projects, and they can be neat. But with the hindsight of experience I hadn't weighted the above types of inconveniences highly enough. But if you really do need to do it all in one largish unit then IMO yes, it might well be possible with class-D amps and a lot of patience and care. For a crossover scenario I would agree with using a single multi-way DAC (or single audio interface), as coherence from drivers within the same speaker is important; 'maybe' separate DACs would work sufficiently well over toslink, but I wouldn't trust separate USB DACs.
Anyway, I shall watch this thread with great interest, since I'm also just starting to take my first steps with a linux-based crossover (initially using camilladsp), teamed with a DM7. Though there are other hardware options like the Behringer UMC1820 and Motu Ultralite mk5.
@Markw4 do you have links/articles about RPi noise elimination or perhaps other ARM systems for running CamillaDSP that are inherently less noisy?
No, unfortunately. In general lower processor clock frequencies and lower power should help. Avoidance of SMPS (another noise source) may help too.
Otherwise I would suggest to experiment. Get an RPI GPIO bus extender cable, hook up the dac and RPi, and move the dac closer and further away from the RPi. Hear any difference?
us
That said, I usually recommend to use RPi as a USB host for a USB dac, and use a USB board for the dac that includes galvanic isolation (such as I2SoverUSB from JL Sounds, at least it works for stereo). The USB cable can be used to provide some physical separation. Also I2SoverUSB sounds best with two isolated 5v linear power supplies. Bottom line IMHO is that is a lot of work to make good sounding compact all-in-one unit. A lot engineering effort to get right.
Well I won’t be contributing much worth. I’m researching and won’t have time to build anything till next summer. I suffer greatly from analysis paralysis - I sweat the small things endlessly too. Hopefully after a few months of researching, I can come up with a great solution for my needs.
IMO for such a multichannel project with integrated amps would it make sense to consider one of the SBCs with multiple I2S lines (e.g. Radxa has a decent SW support) hooked directly to multiple poweramp chips with I2S input (TI PurePath etc.), avoiding USB and DA conversion in the chain.
Reactions: hardy_heron
I would rather use measurement equipment since it’s so much easier to see changes, but I no longer have access to a lab or lab equipment. Although, what ultimately matters is what my (our) ears say.
I have very little experience with SBCs to know all the pros/cons between each. My tinkering mostly involved Arduinos back in my university days…I’m an electrical engineer and am willing to learn.
You have a DVM? Scope? Sound card? You probably need a little bit of test gear to realistically play in this space, but it doesn't have to be a lot of stuff or too expensive.
True. Have to be very careful with human biases though. Easier said than done.
Nope. I have a Fluke 77 that I just wore the rotary selector switch out, so I need a new one. I’d like to get a scope, signal generator, and AC/DC power supply like I had at school, but as infrequently as I’d use it, the purchase doesn’t make sense for me.
I didn’t want to hear that I would be pioneering things. If I had all the equipment and workspace it sounds like a fun (and frustrating) DIY project, but I was not looking to spend that much time/effort…and I definitely don’t trust my coding abilities.
