I have a hum in the left channel of my Counteroint SA-1000 preamp. now before I start I have tried all the tricks to narrow it down with no great success. I fully upgraded this preamp a few years ago and was in heaven with the sound. Until....it slowly developed a hum in the left channel after 8 months of no hum issues and which I thought was a tube going bad. so I changed it, same hum.
now the question is is it a 60hz or 120hz hum? I would love to tell you but my scope is down and the 2 dmm i have one doesn't have a freq measurement and the other that does for some reason is not picking up the hum.
I did the chop stick trick and resolder all solder joint again but not all at the same time.
i have replaced and upgraded all components in the filament, B+ supply active and passive components plus check all the grounds. even replace all the components in the relay circuit. All the B+ caps have been replaced and upgraded to Mundorf Tube cap and Mundorf HV MLAL caps. replaced all active comeponents, Mosfets, Zener diode, regulators twice just to make sure.
All film cap were upgraded to Auricaps (and replaced coupling caps in the linestage again with Dynamic caps), all resistors around the tube have been upgraded to Mills or Caddock MK-132. all tube sockect were up graded to ceramic gold plated. Volume and balane controls were upgraded to TKD, all wire and connectors were upgraded to vampire. upgraded tranny to the plitron for this preamp from altavista audio.
So here's what I did and what the results were. I shorted the signal to ground before the volume control...no change in hum. Shorted the signal after the output coupling cap hum was gone. so it seem like the hum is definitely between those 2 stages of the tube and mosfet. I did do the same in the phono section but no change in hum. this hum originally doesn't change in volume when you turn volume up. Always the same. Now it sounds to me like a 60hz hum cause it seems at the same freq, as the fridge whe it running which give off a 60hz hum noise.
I did find a 200k resistor on the left channel that measured 210k. replaced both 200k resistors in both channels no change in hum.
all the wires from the tranny are twisted now and no change in hum. I'm going to hit all the solder joint one last time before i through this preamp out the window but take out all the parts before I do that!
and i will also solder the grounds from the RCA screw ground point to the ground wire connected to the ground spacer rings that are screwed down for ground on the connectors just to make sure.
Any help would be greatly appreciated.
![headbash :headbash: :headbash:](https://files.diyaudio.com/forums/images/smilies/headbash.gif)
Counterpoint SA-1000 hum UPDATE!
Hello all,
I finally got my O-scope up and running with that probe that I have.
Ok, here's what I fond out today and have been suspecting all along. The HUM is 60hz. But its only coming out of the left channel and doesn't not change in loudness when when Volume is turned up. So I'm suspecting is a bad solder joint somewhere in this preamp.
I have retighten all the RCA connectors and replaced the 200k resistor that I found out of spec that was measuring 210k on the Source lead of the Mosfet and the the other lead of the 200k resistor is attached to ground. I have even again replaced the input and output coupling caps in the linestage just to be sure and replaced all the caps and regulator again in the Filament supply just incase. Still the hum is there!
The only thing I did do from the original design was put a bigger output cap from 1uf/400 to 2.2uf/450 auricap then I replaced the output caps with Dynamic caps 2uf/450. This shouldn't have any affect due to the 100 ohm resister between the output cap and the Mosfet that is used as a buffer between the Tube and output cap.
Like I said in the beginning there was NO hum after I did all the upgrades and it slowly came over 8 months. This Counterpoint preamp was really sounding just wonderul until that Hum and to be honest still even with hum sounds really nice.
I know there will be a very small hum in both channel once I get rid of this Hum in the left channel, but original littel hum was so low you would have to get up to speaker to hear so that is just the nature of the beast with this system so that 60Hz hum in the left channel is audible from 8 feet away so I know this is not normal.![headbash :headbash: :headbash:](https://files.diyaudio.com/forums/images/smilies/headbash.gif)
Any help now that I have identified the frequency of the hum would greatly appreciated. I will keep at it but any advice is really appreciated it.
Thanks everyone for all the help and suggestions! Please keep them coming!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Hello all,
I think I may found the problem....
I started doing resistance checks again and notices that the area where that 200k [COLOR=#009600 !important][COLOR=#009600 !important]resistor[/COLOR][/COLOR] (the one that was mearsuring 210k)and 100 [COLOR=#009600 !important][COLOR=#009600 !important]ohm[/COLOR][/COLOR] resistor attached to the Source lead of the Mosfet in the bad left channel was measuring 2.1 meg to [COLOR=#009600 !important][COLOR=#009600 !important]ground[/COLOR][/COLOR]. The good channel was measuring around 200k to ground. snipped the Source lead of the Mosfet in the bad channel and measurement immediately went to 200k, did the other mosfet too which was measuring close to 200k and now has the same measurement of 200k. I must have damaged the Mosfet in the left channel when I was either changing it or was damaged due to the original 200k resistor being out of tolerance. Hopefully this will be the cause of that hum.
I will post back the results in a few days.
Hi Chris,
I moth balled it for now. I think I may have found the issue and I will be removing the Plitron transformer from inside the chassis and mount it in an external chassis. I accidently found out that it was inducing some hum into some surrounding components. This should fix the problem cause I didn't have this issue until shortly after I did this upgrade.
Btw, I did fix that Counterpoint SA12 amp that Green Street Audio modded. But after a few months it blew that right channel again. Did you finish that mod you were working for these? It's been a while since I last chatted with you via email.
Steve
Steve
Steve, I stumbled across your thread the other day and noticed Anatech had not responded, so since he and I were chatting i thought id mention to him about this dead thread, and i swear he read it and said ... and i will quote directly from my email
On Thu, Nov 19, 2015 at 12:51 PM, Chris wrote:
Hi Nick,
I was away with some medical issues when he posted this, shame I never Never knew about his problem.
Hum, probably the transformer case lost it's ground.
-Chris
Now that may or may not be the problem but I think its awesome that he read that and it sounds like for the most part you and he were already on the same page.
For what its worth i am trying to figure out how to send him an SA-12 myself for jsut that mod .. ;-) he definitely has ideas for this
Hi Nick,
-Chris
Anatech was very helpful to me back in 2011 when I accidentally let some smoke out of my SA-12.
My story still has a possible happy ending. Another member stepped up and offered to donate the original matched fets from the remaining good channel of an SA-20 that they were gutting because the other channel died.
I've been sitting on them along with some other caps and etc. that needed replacing while I gain some more experience and build up my nerve to attempt to fix the amp.
I would like to know if Anatech is up to taking on this kind of work.
I wont speak for him on that ;-) but i know there are better ways to skin the cat than what Counterpoint originally produced, a bi-polar design that is where even Michael Elliott started raking people over the coals for his modes went eventually (sorry if that's not polite or a thread crap) but the point being
yeah .. hes definitely got some end game fixes
Hi Steve,
The Plitron transformer would do it as you found out. This was an "upgrade".
To be honest with you, I hate extra boxes hanging around. The original transformer was an EI core, and there wasn't any problem with those. I would highly recommend that you install a good EI core transformer and be done with it. By the time you have bought a box, cable, feet and all the rest, never mind the labour, you'll be up there anyway. Doing it this way gives you a power transformer for another project.
Yes, Nick very kindly alerted me to this thread. I am very sorry I couldn't help you out back then.
-Chris
-Chris
Hi chromenuts,
Yes, I will be doing this kind of work. I do need some time to get a new bench installed, and to clear some work I already have here.
I will be finalizing a design for bipolar transistor outputs for the SA-12 / 100. A prototype has been running fine for years now, and it is far better sounding than the original. It runs cooler too. It does retain the "Counterpoint sound", and is also quieter on top of that.
The modification is a big job as it changes a great deal, adding three circuit boards in addition to main board changes. I also have a mod that uses the mosfet transistors, but when they heard the "bipolar" SA-100, interest in the mosfet model died completely.
-Chris
-Chris
Hello,
I need help with a SA-1000 here that has blown diodes D205 to D207. I just need to know what diodes go where. Unfortunately I cant find a service manual just a schematic so if someone can look it their SA-1000 that would be very appreciated
Hi Chris, sorry for the very late reply on this as I have been very busy with other stuff. I hope are doing well now?Hi Steve,
-Chris
I still have the Counterpoint SA-1000 preamp but still sitting there waiting for me to repair it. I will get an Edcor Transformer for the SA-1000. As I remember, I never had hum issues and it all start when I put that Plitron transformer in but I also did so other "Upgrades" to the preamp like adding the Mundorf 47uF film cap in place of the original 47uf 450VDC Electrolytic cap. I broke my own rule of doing one change at a time to make sure it something went sideways I knew what caused it. I also found out years later that the cables I was using for the Turntable were adding some hum as well. There was no hum when the system was in Linestage mode only and with the removal of the transformer.
I got rid of the SA-12 and think the main problem with that amp was they used the wrong type of bolt for that transformer which would induce some how was a Plitron for the SA-100 after around 20-30 secs after power up it would have a nasty hum sound but slowly come as the amp was on. I bought the amp broken and it had more issues and after all the fixes and different issues I just cut my losses.
I'm about to pull out the SA-1000 and start work on it, so I will take my time and be posting my findings/issues here IF I run into any or the success!
Steve
Hi Steve,
Well, I rebuild these often enough. Step #1 - remove all the stupid upgrades and have a look at the PCB to see if it survived. That's with all models. Once idiots get inside these all bets are off.
I have yet to work on one I couldn't resurrect. Some can be expensive and it's all about the damage caused. All I am going to say is that you need to ignore the internet completely. Put it back to factory configuration and it will work passably well. I upgrade circuits for higher performance and reliability, but those are things I do and they are not published.
I do get all models from US customers as well as Canadian customers. What I see come in can be pretty sad. Sadder still is the money already wasted, or efforts. Generally speaking, everything done beforehand is wrong. Once properly repaired, people notice the improvement in sound quality, and many still can't believe their units are still working years later (as they ought to). This just goes to show you how bad service is out there.
Hi Chris,
Yes, I did start to do that back when I removed the Plitron Transformer. All components Values were never changed, just had installed Auricaps and some Dynamicaps of same values along with Mills resistors per what Alta Vista was doing at the time. The big change was that 47uf film cap on C201 spot.
I have learn from past mistakes that put the gear back to original state to remove any issues, get it back working fine and leave at it that. I had bought some Counterpoint gear that had been modded and I had to remove all the new parts and mods, they were really hacked up so I know what you are seeing and talking about them being in bad shape. I had bought a SA-3000 from a guy in P.R. and he did so many mods/changes I had to contact Mike Elliott's Tech that worked with him, he lived here in San Diego, he was really upset that someone did that to that preamp. I had he put all back to original form. This issue was when I first got it I was reading the manual on how and what to look for when powering up and some of the LED's in the Power Supply area were not lighting and I didn't want to connect it to my amp and have more issues. The guy that I bought from assured me it would be ok but I didn't trust it and if I had known that in the beginning I would have never bought it. There were quite a few parts removed from what that guy did. The SA-3000 was put back to factory specs and it worked fine until I sold it.
Since I had posted this thread I have build a few Tube kits one being Latino VTA-120 power amp and Transcendent Sound Masterpiece 300b preamp. I just kept them simple to the original instructions and parts except better switches and volume controls with no issues since the build have been completed. Others start to stray from the parts or build instructions and have all kinds of issues and want the designer to help with the repair after they did something totally different
Back to the Counterpoint SA-1000 I have, I did buy new Electrolytic Caps The 100uf 450Vdc on the B+ and the new Electrolytic 47uf 450Vdc. I also bought new LM350K and looking for Q201 2N3440. All the rest of the caps are still original values. The new caps are BC Components and Epcos caps.
Hi Steve,
Okay, very good start.
I do things differently. One thing you can is do is use a TO-126 case transistor in place of the 2N3440. They make small heat sinks that will fit. You will have to reduce the size of the leads so they fit the PCB, and rotate the part so the leads line up.
If the LM350K works, leave it. This is the heater supply and the AC performance isn't as important as the B+ stage.
-Chris
-Chris
- Tubes / Valves
- Counterpoint SA-1000 Hum in left channel Pinging Anatech!
