Really small enclosure for Peerless
PLS-P830985 cannot perform well in a small box.
Yeah, at this small, might as well let verderame set a max HxWxD o.d. box size and he can ~aperiodically tune it to 'taste'.
The measurements I had in mind are not that far from the design proposed by nandappe, we can assume max HxWxD 20x13x13.
Nandappe, I assume your comment was ironic, as far as I can tell from a video on YT they don't sound bad at all, this could be a viable option.
Reactions: GM and LeifB60
In the end, this is the result! It took me a while to arrive at the final result, the construction itself was quick, all material I already had at home, 10mm mdf for the case, I already had the connectors and the metal plates I used for the connectors are also old parts I already had. The only real expense is the drivers and the paint.
I have been listening to them for quite some time now and I must say that for their size they are really amazing! I'm really impressed, no joke, the reproduction quality is really good not to mention the bass...but how does this mini driver do such a job?
Bear in mind that I normally listen with jeff bagby kairos + sub. I tried connecting these mini speakers to the subs of the Kairos and they gave me some nice satisfaction. Obviously all this in the nearfield and at low volume.
Thanks nandappe!
Hi nandappe,
after the pleasant experience in the construction of these mini speakers I had the intention of making small rather narrow towers to be used as a stereo system for a projector, among your projects I've seen interesting things like:
STAG-T8 series
STAG-T5 series
[s04]MS-802T-mk4
[s08]TB-10F_01
The size of the baffle should not exceed 15cm, the less the better.
I was looking for something that had a fairly natural timbre and a decent extension on the low notes and was effective on film speech. do you have any advice for me? Thank you.
For movie speakers, I want more than 4 inch.
For natural sound and extended bass, DDVP-10 is recommended.
It is no problem to make the width (154mm) 10mm narrower.
It would be interesting to make it with 144mm width and install FOSTEX FF105WK.
