My Right side woofer had a terrible buzz. Fixed it with a shop vac!
Moderator
Joined 2004
What's that buzz? My right side woofer was buzzing something terrible and needed to be fixed. Here are two pictures of the problem.
A brand new hive. How to get them out? With a shop vacuum. All 10,000 of them.
Let the jokes begin.
Reactions: Arez and AllenB
Put a bit of tobacco leaf stem inside the cabinet, with some Neem leaves...and if you think safe, put naphthalene balls.
The odor disturbs them.
We have small bee like insects, I just use an oil can to put a few drops of engine oil on their nests, the nesting smell is disturbed by that residue.
Inside a cabinet, I would not do that.
You can use a pouch of muslin like material to hold the insect repellent in place, and stop it flying around.
I was thinking the same whether the bees could be smoked out or by other means chased out, they do better job in the nature than in a vacuum cleaner.
At least I hope you salvaged the bees wax, can always roll your own audiophile caps and transformers. :)
The beekeeper gave me the number, I certainly didn’t count them all! I was a young hive, no more than 4 days old. You can see the combs are white and have no honey.
The vacuum was mild, so as to not injure the bees. They were actually sucked into a hive, not the shop vac itself. The hive was inline before the vacuum - a screen in the hive was used to keep the bees from being sucked into the actual vacuum cleaner.
