PA Subwoofers to use with EV ELX200-15p Speakers
What about these two drivers, as an alternative to the B&C 18TBW100?
  • SB Audience Rosso 18SW800: More sensitive (99db vs 96db), a bit less xmax (11mm vs 12mm), lower LE (1.25 vs 2.45mH), lighter cone (200gr vs 245gr), cheaper (276€ vs 327€).
  • Beyma 18LEX1000Nd: More sensitive (98db vs 96db), a bit less xmax (11mm vs 12mm), lower LE (1.6 vs 2.45mH), lighter cone (185gr vs 245gr), same price, seems a recent Beyma design, uses the latest Malt Cross technology, almost indestructible (60 mm peak-to-peak excursion before damage), much lighter (7.3 kgs vs 15.5kgs).
The SB Audience seems a great alternative if you want to cut costs.
On the other hand, for the same price, the Beyma seems a much better driver.
Just a quick note about the "almost indestructable" aspect: if you hit any subwoofer with lots of power below the port tuning frequency, it can be destroyed in short order.
I folded the cone of a Beyma 15P1200Nd this way. The excursion was impressive, though.
Chris
The sensitivity is measured on a flat baffle at higher than sub frequencies you will probobly find all of them to be simlar if you simulate them. Also different manufacturers will report xmax differently as many of them include extra xmax for fringe field effects. For B&C they report both the geomatry derived xmax and also a figure xvar which is from kipple analysis that gives the maximum linear excursion. Realy it would be great if all manufacturers just gave a kipple driver test report, you can try asking but they quite often want you to be an established company to give this data. This is quite ammusing as when you see the kipple reports for things like 18 sound drivers they are astoundingly good so would make great marketing material. Anyway what I'm trying to say is that beyond gross clasification of drivers looking for small differences in xmax and sensitivity data isn't telling you much.
Voice coil magazine is a free subscription and tests drivers. Looking at a Beyma driver using the same technlology:
https://audioxpress.com/article/test-bench-the-beyma-12lex1300nd-pro-sound-woofer
overall performance looks good but the xmax is over stated on the datasheet:
". Displacement limiting numbers calculated by the Klippel analyzer for the 12LEX1300Nd were XBl @ 82% Bl = 8.4mm and for XC @ 75% Cms minimum was 4.6mm, which means that for this Beyma driver, the compliance is the most limiting factor for prescribed distortion level of 10%. If you apply the less conservative 20% criteria, XBl goes to 10.3mm and XC to 8.3, so definitely better."
I'm not sure what distortion level B&C use for xvar but it looks like it would be rated for considerably less than 11mm xmax by them.
Reactions: neo2015
Thanks for the link to the LEX review.
It seems to re-enforce the idea of the Beyma driver being the best of the 3 that i mentioned: "... [the LEX driver] looks to be a very well-crafted driver with a good set of performance trade-offs, not to mention a world-class cooling system with Maltcross.
We use 10*Fane 18XB in bass reflex subs tuned to 40Hz with 2000W per driver. No issues they are very solid drivers, in sufficent quantity the output is good and the prime is presumably an upgraded version.
For small events we often use two per side with a 12" coaxial top.
Thank you all for your input.
After some simulations on WinISD with all the drivers mentioned on the thread, I'm choosing the B&C 18TBW100, the reasons are:
  • Costs are similar
  • No SPL advantages (B&C is slightly better on the lower frequencies)
  • Availability, it appears to be easier to get (will see about that...)
I did some box simulations on subbox.pro to get an ideia of the final size os the box:
Link: 170L Box at 37Hz
It is 675 × 550 × 653.9 mm now...
WinISD simulations (with highpass filter to protect the driver):
BLUE: 170L 37Hz
RED: 170L 32Hz
PINK: 115L 37Hz
I think 37Hz would do well for my application, DJ work, playing a little bit of everything, some EDM, Hiphop, Latin, Rock, etc...
Do you agree?
What king of bracing do you suggest?
I don't have any experience with this type of alignment (all my DIY subwoofers and speakers are sealed), so i don't know if this would apply.
But looking at Ricci's files, his designs are heavily braced, such as:
Skorn:
CKRAM:
Maybe you can use this type of bracing in your design?
