GRS 8FR-8 Full Range Low Budget Project
Have here a nice and cheap pair of GRS 8FR-8 drivers and like to put them in a simple cabinet.
Data sheet GRS 8FR-8:
Resonant frequency fS 39 Hz
Electrical Q QES 0.46
Mechanical Q QMS 2.94
Total Q factor QTS 0.40
Suspension equivalent air volume VAS 64 litres
DC resistance RE 7.02 Ω
Voice coil inductance LE 1.28 mH
Maximum linear excursion Xmax ± 3 mm
Efficiency η₀ 0.81 %
Efficiency bandwidth product EBP 84
Overall diameter 203.2 mm
Baffle hole diameter 184.1 mm
Mounting depth 98.4 mm
Diaphragm material Paper
Voice coil diameter 38.1 mm
Magnet Ferrite
Proposal:
Reactions: Haze Head
Again some little modifications.
Added some supports for the looks 😍 .
Guidline 1: braces should be placed such that the subpanels created by the brace should have an aspect ratio larger than the panelbeing braced.
This is clearly not the case in your design, where the aspect ratios are all less. You want to push resonances up in frequency where they will be less likely to get excited.
A reflex box is assummed to be “close" to a cube. As one dimension grows a quarter-wave resonance starts across the longest dimension. Your box is tall enuff vrs width/depth that it will be an ML-TL. The end-loaded driver and vent will maximize the quarter-wave effect.
dave
Reactions: Randy Bassinga
The braces should run vertically. I also take the opportunity to brace the driver/baffle against teh back of the box as well as top and bottom. Braces runnign parallel to the baffle should truncate such that they are not directly behind the driver.
And if you want to model the box you need to use a proper modeler that will handle quarter-wave designs.
dave
Reactions: GM
What? That has little to do with it. And if you are using quality plywood (recommended) each ply has the grain running 90° to the ones next to it.
Grain implies solid wood, something i do not recommend if you do not know what you are doing. Still has little impact on the most effective bracing.
dave
Reactions: GM
Take a look at some of the enclosure designs posted in the libraries below that Dave and Scott Lindgren have accumulated over the past couple of decades, many of which I’ve built myself. They should give you a better visualization of the bracing topology he’s suggesting.
http://frugal-phile.com/
http://www.wodendesign.com/Free.html
edit, actually it just occurred to me that many of Scott’s drawings lack the specific bracing details, but IIRC make reference to including such.
Boy was i wrong.
'Birds of a feather'! My mom made it plain to me and all concerned that no son of hers would ever be a secretary! So continued along a 'jack o'trades, master of none' career only to wind up in an engineering position that required copious written docs of various types to be typed by the secretarial pool and later do it all myself on a computer system, though with all that came before being eventually uploaded, so all I had to do was 'tailor' it to the current project.
Friends. Please dont tell me how to brace this low budget speaker box 😃l have made a lot in the past.
For this speaker its more than enough 👍.
