The best bass ever heard (and possibly affordable)
They're PA subs with a 32Hz tune using 2x18s and for a large concert rig, not even that many of them. Yawn.
Good thing Mark100 responded, otherwise I'd have to educate you! They play down to 20hz, the motors are 0.6ohm and are electrical actuators, not traditional speaker motors.
Let's just say that if you think these are "normal" 18" cabinets, Dave has a stool he wants you to sit on!
for those who went from 15" woofers to 18" woofers, still a clear advantage? going from 12" to 15" is such a obvious upgrade, I kinda hope going from 15s to 18s will still be a sizable upgrade... (range I ask is 30hz-300hz)
What is the disadvantage you believe you have with 15" drivers? I have a combination of custom made 10" and 12" subwoofers, with some DSP multiple subwoofer trickery...and I'm pretty sure I'm not missing out on anything except room modes!
It's fun to experiment, but I doubt there is anything to be gained. The larger drivers may distort more, even though it probably isn't audible. Setting up multiple sub system with DSP is the proven way to get the best possible bass response in a small room.
PS: where are the measurements? Pref CEA2034 so we can have some sort of reference with other drivers. What's the upper BW of them?
Just being large is like saying my car has 3000BHP. Impressive, but where are the times from the 'Ring that show it can actually use it real world? Even a 1/4 mile time would show it's able to put it down, which at least gives it some idea of it's worth. I had 4 LABsubs in my room at one stage (20ya), and whilst huge and have a 'wow' factor are far from the best performing subs I've had.
How about open-back headphones then? Are they not near field?
The wavelengths involved are just a bit longer than the chamber between the headphone and the ear, you can't really develop bass resonances in there.
But it has no relation to the idea of near field bass in a room
headphones cannot be compared in terms of near field bass
In the headphone case, there is a room but it's very small. Any resonances or standing waves that might form would be well above the bass range.
Thanks Bill for the good reply. I can see how very close subs can sound good as the bass reflections from the room will be at a much lower level that the bass coming from the sub that is about a foot away from the listening seat. A friend of mine told be about the precedent effect where the loudest sound source will be the one we hear over a lower level source of the same sound. So I wondered if a very close sub would be what we hear over the bass reflections of the room, and if other people have found this to be true. If this is true it would really help dealing with un-even bass response at the listening chair if we could just place subs right by the chair and get a flatter listening experience.
The reflections will not be at a "much lower level" (at least in a relatively live room of domestic proportions), they will be close to the same volume as the direct signal. Precedence won't help with wavelengths that long. What you hear will be the reverberant field with all of the reflections and resonances.
Room treatments that could absorb low frequencies enough to reduce the levels of reflected bass could change that, but those treatments would probably make the whole question moot by improving the bass no matter where the sub was placed. The Double Bass Array that Stig-Eric mentioned is another approach, but again not cheap, or easy to achieve in an average home.
Why would they? Less cone movement for the same SPL would mean less distortion typically for the same motor design.
Because the larger cone is likely to flex more at low frequencies, and that flexing causes distortion. The bigger the cone, the harder it is to make it stiff enough to not flex without adding excessive amounts of mass to it. Square-Cube Law applies.
It's been said that the best 18" subwoofer is a 15" subwoofer.
Are you confessing to making bad subwoofer decisions in your past?
The problems created by putting subwoofers in a room will never be fixed by a bigger subwoofer. All I can do is suggest getting in with the new school and working on DSP subwoofer control. Keep what you have and add DSP.
Dave's circle of super subs would be the ride of your life! I hoped that was obvious? You will have to go to a concert in a stadium, where these subs are being used, to see if they "sound good".
I got my first DSP in 02 and have been designing/using active speakers since then for hifi, HT, PA and some fixed install jobs.
Riiiight. So a larger driver is worse because of poor design choices. The motor is typically a far higher cause of distortion than cone flex. Of course, if you have actual measure data of high performance driver, not some cheap crap, that shows this (cone flex causing more distortion than the motor) to be the case, then please post it.
Quote me a reputable designer that states this, with full context for the comment.
As a human, most of my decisions are flawed in some way and the benefit of learning more. However, name me a sub that could be had at the time with more output and lower distortion.
Your comment is an attempt at a cheap shot rather than backing up your assertions with data.
That generalization makes no sense to me....it's all about cone materials employed.
This 21" IPAL looks pretty strong to me 😀
And you know Dave Rat's M-Force 30"s gotta be some pretty stiff suckers too.
To simply say a 15" is going to be stiffer than an 18" is way off the mark imo.
Funny....I don't even think a 15" qualifies a a sub driver, unless maybe it's horn loaded or something...
"My room is 5 x 10 meters but fills every inch of it, and also plays 120 db 20 hz with headroom." .... Thats hard (but not impossible) to achieve with 6 good 15 inch (Sd 880) Pro drivers with 4 or 5 inch inch voice coils with 700 watts or 1,000 AES continuous power handling and high Bl low Mms motor / cones.
Its impossible with 6 Peerless 830847 with 466 Sd (11 inch not 12 inch which = 550 Sd as that fat rubber surround wastes 20% of the cone area) audiophile drivers with 2 inch voice coils which max out (reach Xmax limit) at 250 watts AES (forget the audiophile power ratings) ... Thats not a bass driver its a toy.
I only use sealed box not ported (yuk!) speaker so you can add approx 3dB to each of the sealed box sims if you use ported and want to achieve higher SPL at the expense of sound quality.
The sim shows both a single Peerless 830 847 and a 6 driver set up.
Just a few highlights of the Peerless driver... At 20 Hz using 250 watts the cone is travelling at its Xmax of plus/minus 12.5 mm (1 inch) bouncing around on its fat elastic band surround... Its max SPL at 20 Hz is.... Drum roll ... 97 dB !! So for a single driver, 100 Db requires 500 watts, 103 Db requires 1,000 watts 106 Db requires 2,000 watts, 109 Db requires 4,000 watts... You get the picture.
Doubling the drivers to use two instead of 1 results in a real world increase of approx 3 to 4.5 dB when distributed ie you dont gain the theoretical 6 dB for each doubling of Sd due to distributed source interference, so add 4.5 dB for every doubling of the surface area ie Add 4.5 dB for two drivers, add a further 4.5 dB for four drivers and add a final 2.25 dB for 50% increase from four drivers to 6 drivers...
= 109 .25 dB AT 1 METER... But you have a 10 meter long room and according to you the Peerless "fill every inch of it with 120dB at 20Hz with headroom"... Oh really? Point sources drop off at 6dB with every doubling of distance, so your max 109.25 dB at 1 meter becomes 103.25 dB at 2 meters, 97.25 dB at two meters and 91.25 dB at 4 meters listening distance in your 10 meter long room.
So I would suggest that even if you sacrifice sound quality and go ported instead of sealed box to gain a few more dB, you are still a world (galaxy actually!) away from the 120 dB at 20Hz with headroom in every inch of your 10 meter long room...
While I subscribe to the general conclusion I could not help but notice a few errors. At 20 Hz the sound field in a 5x10x3(?)m room is half way a pressure chamber, half way a modal field. Of course the point source approach in such a sound field isn’t correct so any decrease in SPL with increasing distance from individual sources isn’t that likely. Even more, room modes tend to build up SPL in the velocity nodes. And the calculation of SPL from a certain Vd at 1m distance normally is only valid for half space or full space placement. If using corner woofers, the SPL per 2,83V rises significantly due to the increased radiation impedance on the cone.
All I hear are contradictions! I asked what your 15" drivers are missing, but you didn't say.
And now you are coming after me because I said 18" drivers can have disadvantages compared to 15" drivers!
By questioning me, the burden of proof is now on you. So go ahead, prove to me that 18" drivers are always superior to 15" drivers. But keep in mind that if you do attempt to prove it, you also cast doubt on the intent behind your original question.
What's up with you guys? Is an 8" subwoofer not a subwoofer because today you decided that a "real" subwoofer is 21"? Is there an application process and a governing body that controls what drivers can and cannot be called a "subwoofer"?
I believe you know that what you're saying is BS.
Yep, single 21" woofer has cone area of about eight 8" drivers, or about two 15" drivers. One could use 8" subs, just use many enough to get some SPL out of the system. Use four 8" to match single 15" in capability.
Single 15" gets octave lower than single 8", or 6db louder with same extension with same input power. To get one octave lower quadruple cone area so instead of one 15" use two 21". Its just what the maximum SPL is out from the system with some particular extension. Simplified of course. If cone flexing is concerning you could use loads of 8" drivers. I'm not sure its much of a concern in home hifi use, systems are hardly pushed to max unless too small driver.
edit.
Never seen pro woofers "flex", so googled around and youtube finds
with click bait title. Reading from the comments its a custom woofer with too thin cone, so, why its labeled pro woofer if its not for pro use..
