Transformer helping transformer
Might be worthwhile to prototype some kind of EI-core transformer version of the steel bell that's pretty common with toroidal transformers.
_
Reactions: Rick Miller
Isn't subjective listening impressions the only thing that really matter in the end? We have our equipment to give us enjoyment thru listening to music.
Yes, I agree.
However, if we want to compare equipment or determine does some effect really exist, single person’s subjective listening impressions are not good enough. We are champions of deceiving ourselves.
Placing soft magnetic material on top of a (cored) inductor/transformer increases inductance.
Oh? How? The vast majority of the magnetic flux flows in the core, so unless you get the added material to somehow participate in the core area I don't see how you can increase the inductance appreciably. Sure, you'll probably change the stray fields a little bit, but they are pretty small in a well-designed transformer.
The next question becomes: How does increasing the inductance of a power transformer change the sound quality? My guess: It doesn't.
OK, so how about output transformers? Let's say you put the brick atop a typical 300B output transformer with a primary inductance of 10 H. Somehow by magic (or by interaction with whatever stray fields) the inductance changes by 0.1% to 10.01 H. Will that change the characteristics of the amp? Probably. Maybe even measurably. Would you be able to notice the difference in an A/B test? Probably not.
All the babble about mechanical resonance control is pure snake oil in my view. Maybe with one exception: I could see a case where a very microphonic tube would benefit from added weight on top of the panel the tube is mounted to. I do not see a use case in a solid state amp. If your solid state amp design is microphonic you should probably go back to the drawing board. Of course, none of this prevents manufacturers of $100k amps from claiming that their milled from a solid block of unobtanium chassis is special and has patented/proprietary/ultra-special resonance control. Recall that the only requirements for a patent are that the invention is novel, non-obvious, and reproducible by anyone skilled in the art. There is no requirement that the invention has to work or do anything useful.
Tom
... Will that change the characteristics of the amp? Probably. Maybe even measurably. Would you be able to notice the difference in an A/B test? Probably not....
Sorry Tom, but you show no measurement of non significant acoustic effect, I think that it is not fair to the OP who simply asked other members. It has always ben a conundrum, those with exceptional hearing ability are not technically oriented while those with engineering background (like me) are not blessed as much in hearing ability. When one with exceptional hearing works hand in hand with an engineer we then have stuff of legend such as CTC Blowtorch, DH200 and Threshold.
My problem is with the claim about "exceptional hearing ability" 🙄
Specially when stretched to nonsense levels.
That it is OFTEN coupled to nil/zero Technical prowess does NOT make it more believable, quite the contrary.
Lack of logic/reasoning skills, even less.
On another DIY audio forum I read about placing a un-connected power transformer on top of or right next to the power transformer of a amp, preamp or other audio equipment. It is said to make the equipment sound better. The exact reason is unknown, but thought to have to do with the radiated field of the power transformer being influenced by the in-active transformer’s core material. This is easy to do with EI core transformers, just set a spare EI core transformer right on top of it. I have tried this and it does make the equipment sound better, more open and dynamic to me. Has anyone here tried this simple experiment? Most tube equipment has EI core power transformers.
Better tigthen up those loose screws...transformer or listener...one of em propably has loose screws
It's the mechanical acoustical dampening from the weight of an additional transformer.
There's no electricity involved in that and you can use anything heavy, of course different materials will give you different tone.
The same applies to cables and plugs.
No, the variety of materials you can add can bring a lots of possibilities for tone. You bring sparky highs or thicker bottom end, depending what you put.
The same applies to power transformers, they're not equally made. Copper grades, dielectric and cores all have tone characteristics.
