Thanks for noting this.Keep in mind that speaker cabinets, sub-woofers in particular don't make good tables if you plan on putting things on them. Cabinet vibration will cause things to slowly move to the lowest point or edge and eventually fall off. Maybe some type mat might help if that was your plan.
We usually dont have much on the table. Maybe a candle, but we dont light it up.
Ill try to get more reading using REW to see if the table move or shake too much and I have to move the table on the side of the couch if the response would make sense.
Haha. It was a joke. There is a 12" subwoofer entry in this "table" of HF drivers. Sorry to take your time, was just trying to give a laugh. 😂Thanks for your reply, but I'm scared I dont understand what's this table is for. Care to explain a bit better ? All i see are 1in and 2 in drivers.
https://docs.google.com/spreadsheets/d/1NHk_VB5l74ctKoKOJa3lTkADW_v7f8S_zpc9YsItUyE/edit?usp=sharing I found simply intermixing with similar color and font as well as same brand makes it pretty straightforward let me know if you need any other help 🙂
What would be really trick is a bunch of neo magnets embedded opposite polarity between the top of the cabinet and the "tabletop". The cabinet could extend up to slightly below the top of the tabletop, and some less powerful neo magnets could be embedded laterally so as to keep it centered. So you would have a hovering and decoupled surface.Keep in mind that speaker cabinets, sub-woofers in particular don't make good tables if you plan on putting things on them. Cabinet vibration will cause things to slowly move to the lowest point or edge and eventually fall off. Maybe some type mat might help if that was your plan.
oh god!! hahaha English is not my first language, and I didnt even think about google doc as a ''table'' hahahahah good one!Haha. It was a joke. There is a 12" subwoofer entry in this "table" of HF drivers. Sorry to take your time, was just trying to give a laugh. 😂
would need to check a DIY tutorial because I have NO ideas how to make this!What would be really trick is a bunch of neo magnets embedded opposite polarity between the top of the cabinet and the "tabletop". The cabinet could extend up to slightly below the top of the tabletop, and some less powerful neo magnets could be embedded laterally so as to keep it centered. So you would have a hovering and decoupled surface.
he meant like having the table top hovering over the sealed box. in order to not have the table top vibrate with low frequency.bo44, would that not just create a very large and leaky passive radiator system?
Why not isobaric sub? Its easier to hide the box half the size.thanks for your answer.
Great question.
Linked osme picture of my living room in sketch up an fusion with positionning of the table.
table will be 'very near' couch and wall. Like 1 or 2 ft max. I was planning on either, getting the cable under the rug, and poking a little hole in the rug to get the wire out. Or just running it on the rug with some kind of cable hiding tray to hold it still. Its not onlu just go there to sit down and watch tv, not a high pedestrian hallway.
if going slot port, I will dust it using a swiffer or something.
yes, children, 1yo. Thats why, and WAF, I wanna hide the drivers. But if not worth it, Ill go the first box with opposing woofer at the ends with a cloth grill. I just kinda think the slot 'port' looked special and great and without beeing too much 'in your face' would be a good conversation starter and we could even see the woofer moving.
Also, booger welz commented this on my other post:
https://www.diyaudio.com/community/...-a-home-theater-subwoofer.393057/post-7199867
and I love those design. so was curious to see if anything viable could suit my need and situation.
As for the down firing option, by definition, it wouldnt be opposed firing driver?!
Hope it clears things up a bit!
Exactly. and in terms of a simpler solution, you could use drawer liner and coasters / table top trays to get close to the same thing.he meant like having the table top hovering over the sealed box. in order to not have the table top vibrate with low frequency.
I've built enclosures from MDF and from Birch, with both having some fiberglass in some cases. The box I constructed from birch was by far the most reinforced and braced and while I can't say I had an identical MDF enclosure of the same design, I thought the birch was more prone to cabinet flex than if I had made it from MDF.
But if you have the coasters for candles or drinks, in addition to a generously dimensioned table top tray (classy, made of wood, not some TV dinner thing) underside's lined with the same sort of sticky, non-slip drawer liner, I would expect it to be usable.. I'd still opt for a run at the magnetically levitated version though. Would be very cool.
I don’t know why not.Why not isobaric sub? Its easier to hide the box half the size.
I remember trying to model it in winisd, but can’t remember the outcome.
Why would the box be half the size?
Will have to google that one out. I’m not familiar with this.Two Ripole subs would fill the bill. There is reference at Jazzman's electrostatic speaker build for these subs. Seems that each of them uses two Peerless 12" drivers and the cabinet is small for each.
Edit:
For people interested:
http://jazzman-esl-page.blogspot.com/2011/01/ripole-subs-are-underway.html?m=1
Its just a function of the design. You only have one speaker radiating sound. You also would be down -3 dB if you had the same impedance. But by wiring the subs (single) voicecoils in parallel, you gain that +3dB back. And at half the enclosure volume. I've never built one, something tells me you'd probably be down a little more than -3 dB just due to the more difficult construction. But with half the requisite enclosure volume, it can make sense for tight spaces.I don’t know why not.
From his description, it’s not very suited for HT, but seems very smooth for music.Two Ripole subs would fill the bill. There is reference at Jazzman's electrostatic speaker build for these subs. Seems that each of them uses two Peerless 12" drivers and the cabinet is small for each.
Maybe I got what isobaric is wrong.It’s just a function of the design. You only have one speaker radiating sound. You also would be down -3 dB if you had the same impedance. But by wiring the subs (single) voicecoils in parallel, you gain that +3dB back. And at half the enclosure volume. I've never built one, something tells me you'd probably be down a little more than -3 dB just due to the more difficult construction. But with half the requisite enclosure volume, it can make sense for tight spaces.
Isn’t when the 2 speaker face each other inside a box?
I don’t understand how you have only one driver radiating?
Like I said, I have a lot to learn still! Haha
2 UM15's or even 18's will be plenty, use the KISS theorem and go sealed you have enough amp and space even for the 18's to have an awesome low roll off.
I would make the table free standing over the sub cabinet, hide the subs behind some nice grill cloth
I look and save all the links you provide for future reference and when I have a bit more time to read into them!
So a box under a “conventional” table.2 UM15's or even 18's will be plenty, use the KISS theorem and go sealed you have enough amp and space even for the 18's to have an awesome low roll off.
Gotcha.
Yup. Got plenty of power.
What stop me from using um18:
1- driver price if going for 2 drivers, which is recommanded in order to keep vibration low.
2- limited by the table size. 18’s doesn’t quite fit into both end pannel of the table.
I remember the Decware Audio site having plans for a two-driver cabinet. Again, I forget what it is called, but it is a horn loaded design of a size that would make a great coffee table because it lays on its side. IME horn loaded designs can have the punch needed for HT.
- Subwoofers
- Ways of hiding subwoofer in a table : ideas needed.
