What is the point? You haven't explained why you replaced the parts you did.Cement Resistor vs Cement Molded Resistor?
Metal Plate Resistor?
Fire Proof Resistor?
Aluminum Electrolytic "Z" Type?
SBL Film?
MS?
UPF?
Carbon Film vs Fireproof Carbon Film?
Semiconductive Ceramic?
PS, I worked at Panasonic in it's heyday. Panasonic built almost all it's own components unlike Yamaha which only built semiconductors.
PART 3 OF QUESTION:
#1 Replace Ceramic with Film?
#2 Replace Green Drop Mylar with Orange Drop DME?
#3 Replace Fuse Resistor with Metal Film?
#4 Replace with MJE15032G & MJE15033G?
? Green Resistor?
? Red Resistor?
Items marked with a ?: Are these acceptable substitutes? Anything better?
Pink Resistors are TAKMAN REX
Fuse Resistors are TAKMAN REY
? Green Resistor?
? Red Resistor?
Please accept my apology, the unit was worked on prior and had many failures. This is also an opportunity to see if newer technology can make a sound difference.What is the point? You haven't explained why you replaced the parts you did.
When I worked for Siemens Medical Systems MRI Development Group, Siemens also made a vast majority of it's parts, thus I can understand the advantage.PS, I worked at Panasonic in it's heyday. Panasonic built almost all it's own components unlike Yamaha which only built semiconductors.
Well understood, the issue is the wording that Yamaha used 😵What is the point of this? If you want to learn about various resistor types, use Google.
Most all electrolytic capacitors are now replaced with Panasonic FCPS, I worked at Panasonic in it's heyday. Panasonic built almost all it's own components unlike Yamaha which only built semiconductors.
You have the "Starter Package Basic" [tm] which entitles to one component decoding service.Cement Resistor vs Cement Molded Resistor?
SBL Film?
MS?
UPF?
For more, please upgrade to the Pro version.
Only U$9.99 per Month, minimum contract 1 year.
Please accept my apology, the unit was worked on prior and had many failures. This is also an opportunity to see if newer technology can make a sound difference.What is the unit doing ? Noisy, no sound , dead channel etc.
Please expand upon thisYou have the "Starter Package Basic" [tm] which entitles to one component decoding service.
I fear parts rolling "to improve it" 🙄What is the unit doing ? Noisy, no sound , dead channel etc.
Might be wrong, of course.
👍🤓I fear parts rolling "to improve it" 🙄
Driver and Output Transistors found in unit:
Power Supply/Protection Board
This is what a original board looks like (this person took this photo after replacing the electrolytic caps)
Japanese service manuals are translated to English by people who's native tongue isn't English and many don't have technical background. When I was a product manger for Panasonic I would cringe at the verbiage in the Service Manuals. Our Service Group was full of US citizens without a technical background as well.Well understood, the issue is the wording that Yamaha used 😵
Today you would be hard pressed to get a service manual for any product. Even if you could, you wouldn't have the SMD repair station and experience to do the work nor the replacement parts....
Unless you have a curve tracer to test the power transistors you remove, you won't know if some are "leaky" or have breakdown issues. Replacing every part with "modern" or possibly Chinese counterfeits is only inviting trouble. Unless your source is credible, you might be putting in counterfeit crap parts....
While at Siemens we called it Germish half German/ half EnglishJapanese service manuals are translated to English by people who's native tongue isn't English and many don't have technical background. When I was a product manger for Panasonic I would cringe at the verbiage in the Service Manuals. Our Service Group was full of US citizens without a technical background as well.
While at Toshiba we called it Japish half Japanese/ half English
No one had a clue to what was being written.
I am using the full line of Peak Electronic Design test equipment
I only purchase parts from Mouser, DigiKey, Parts Connexion, HiFi Collective (UK)
Thank you! I paid up! 🙂You have the "Starter Package Basic" [tm] which entitles to one component decoding service.
- Needing a 1970's Yamaha Engineer (employed by Yamaha)
