Troel's Loudspeaker 3 versus Faital 3WC15
Hello,
I have several questions, regarding Troels design or general design for a 3 way with speakers (no compression) :
He chooses 15pr400 because it is very good in the mids and crosses at 230hz. The mids play between 230 and 2800. He chooses an 18s 8". Of course he uses simple passive crossovers so the slopes are low order slopes...
My questions would be, if we assume that max SPL is not the purpose.
Do you prefer a 6.5 or an 8 to play between 250 and 2500?
If such a 3 way is used, where would you put the lower crossover? Higher than what he does ?
If DSPs are used what kind of slopes do you prefer?
What mid would you pick ?
Regards Greg
I would have liked to know a Hypex preset for the 3wc-15 based on good measurements
for me, it s better to cut a 230-2000 and not 2800Hz ..
but why not. the 15pr400 is good if you want very light bass with 4 cu ft
Icône de validation par la communauté
There can be different reasons why changing your crossover point helped. For example, what if each driver has a different floor cancellation frequency because they are at different heights?
So you can't simply say it's the crossover by itself, or even the driver.
Yeah you're right could be lots of things but maybe simply my 6md38 is not done for 300hz, this is were its rollof starts and I'm using it open baffle... Actually even the upper mids seem better.
All the measurements I made were not bad down to 300hz and it is not a bad listening.
I have 2 headphones,
Audiotechnica ATH-W1000X, Sennheiser hd650.
If you cross at 500hz you are more like audiotechnica, at 300hz it is more like the hd650...
I run a pair of speakers for the stereo setup in the living room with the open kitchen that are taken from the loudspeaker II idea of Troels Gravesen.
2 X 15 inch open baffle subwoofer, 10 inch kick bass low midrange, 18sound NSD1095N compression driver plus XT 1086 horn and Visaton TL16H super tweeter with a subwoofer plus 3 way active crossover with 2 miniDSPs 2 X4 HD devices.
Especially with higher SPL i have never heard something close to them.
Beside may be many many years ago the Beveridge big electrostatic towers or the big 15 Inch Tannoy coaxial speakers, all much more expensive - unreachable for people that do not want to spend a fortune for a pair of speakers.
Hello,
Thanks for describing your setup but coul you give more details ahah, sounds interesting. Speakers, crossovers, load ?
Interesting I was looking at different speakers
Faital 3WC-12
Point of crossover: 500 and 2400 Hz, LR2 filter
Faital 3WC-15
Point of crossover: 230 and 2800 Hz, 2nd order crossovers (LR2)
Tl1:
Four-way floor-stander from 18" +10" + 1" comp. driver + horn-loaded tweeter.
Finished speaker weight: 85 kgs/ea
Sensitivity: 95 dB/2.8V/1 meter
Impedances: MTT section: 4-8 Ohms, minimum 4.3 Ohms @ 600 Hz. Bass section 8 Ohm, minimum 6.5 Ohms @ 25 Hz. If run fully passive from one amplifier, minimum impedance will be 3.0 Ohms @ 120 Hz
Points of crossover: 200, 1300 and 9000 Hz....
Obl-15
Points of crossover 180 Hz (6-12dB) and 2 kHz (24 dB).
That dynaudio is quite strange
https://www.dynaudio.com/professional-audio/lyd/lyd-48
Crossover Frequencies:
460Hz / 5.5kHz (5.5 !)
JBL 4312
Description: 3-way 12" studio monitor bookshelf loudspeaker
Low-frequency Transducer: 12" (300mm) pure pulp cone (JW300SW-8)
Mid-frequency Transducer: 5" (125mm) polymer-coated pure pulp cone
(JM125PC-8)
High-frequency Transducer: 1" Magnesium-Aluminum alloy dome
Crossover Frequencies: 640Hz, 5kHz
Last but not least ! Genelec 1238 !
Crossover frequency
Bass/Mid
Mid/Treble
450 Hz
3.0 kHz
420 Hz
3.0 kHz
It s difficult to equalize HP. I have 8nmb420 and 8m400 mediums. I would like to cut them LR24 at 200 and 2000 (or 2800). I equalize (activ) flat before the high pass and the low pass and it never sounds good. I must using too much EQ 😉
On the passiv crossover of the 8nmb420 in the faital 3wc15, there are a not much equalization. it's a shame that troel does not explain what he linearized, with R8, C4, L4
the 8m400 are said more forgiven about the two ! 2000 hz is a little high for most of the 8" : tweeter should cope the 8" beaming there, that is meaning WG use ! Without you should be more confortablle between 1000 to 1500 hz with your 8" ! (and PA drivers are not always easy/smooth.
