Best sounding amp for 12-30V DC?
With a full bridge topology (BTL) you can expect upto 50W into 8 Ohms. Generally, there is no "best sounding" amp - simply because no widely accepted criteria for best sound do exist at all. Actual class-d-chips have reached maturity imho, I prefer the TI range from TPA3116 upto TPA3255.
But there are many ways to spoil these by poor designs delivered from al cheapo far-east traders.
Like Bucks said, bridged Class D will meet your specs.
Modern good quality amps "all sound the same"; if they sound "different" it´s because they´re coloring the sound, hence should better be called "Effects boxes".
I have made this speakers with Seas DXT tweeter and CA22RNY woofer.
I will use it in my off grid mountain cabin. It has solar power and a huge 12V battery.
A Victron DC to DC converter can increase the voltage up to 30V.
I like to play loud. The loudspeaker will be crossed over active with miniDSP 2X4HD so i need four channels.
e36ffcea-6d60-4797-bfe8-0ecbf314a234-jpeg.761834
d1fda09a-38a6-43e7-96c7-128e37c4b25d-jpeg.715962
Got a similar setup, minidsp 2x4 and two Aiyima A04 (TPA3251) amps for powering my speakers. Although I´m swapping amps often and will exchange them in the future, they work fine with 24V.
As mentioned the TPA3255 will provide 50W/8Ohm at 30V.
Haven´t calculated the idle dissipation of a TPA3255 but would reckon it´s around 1-2W. Going lower in voltage (if you don´t need the power) will also reduce that dissipation a little if you want to save some more.
24V for a BTL TPA3255 amplifier will yield around 25W/8Ohm.
I´d definitely recommend class-d amps when being solar powered and listening loudly.
You should talk about all those nice looking things in the background😉
I see 4 huge horns and 2 subs?
You could probably modify shown amp into something OK but I´d stay away from the shown version as it is. Probably ceramic caps for the input coupling.
If you don´t mind soldering a bit, abraxalito offers kits to build mono amps which are probably the best opportunity to try a TDA8932.
You will have to do SMD soldering though.
Regarding the far east cheap designs mentioned on the page prior - i tested several of them and unhappily found large deviation in performance of devices even when from one supplier.
Regarding quality in general: For bass frequencies, there is hardly something better than PDM-audio with digital amping. I am currently using some TPAs for my bass array.
That's entry-level. To get good quality sound from a TDA8932 attention is needed to two main aspects.
Firstly the signal power supply needs regulating. TDA8932 has two sets of power pins - power and signal. Its the signal power pin which is most sensitive to regulation - all entry-level boards I've seen just follow the application in the DS and that shows a simple RC network from the power pins to filter noise going to the signal power pin. That RC simply isn't good enough.
Second - there's a strong chance of RF pick-up between output and input. The easiest way to deal with this is by transformer isolating the input. Which also handles the fact that TDA8932 has a differential input whereas most sources are single-ended.
As @joensd mentioned, I have PCB gerbers you can download and also kits for an implementation which sounds good and attends to the above points.
