What is the Universe expanding into..
Do you think there was anything before the big bang?
  • I don't think there was anything before the Big Bang
    Votes: 56 12.5%
  • I think something existed before the Big Bang
    Votes: 200 44.7%
  • I don't think the big bang happened
    Votes: 54 12.1%
  • I think the universe is part of a mutiverse
    Votes: 201 45.0%
  • Total voters
    447
M. mcchambin, I notice your tidal French "Rance Projet" is a mere 240 MW. 😱
As a man with his finger on the pulse, I notice a modest modern 16 x 15 MW British wind turbines can match this. 😀
I hadn't really considered the effects of our wind-turbines, with a tip speed of 300 Km/pH stunning passing birds. But have solved it. 😎
The solution to Global warming lies in the disputed UK Island of Rockall:
908712d1609885445-universe-expanding-rockall-island-jpg
908713d1609885445-universe-expanding-rockall-location-jpg
Tidal power to the max. Evidently windy and perfect for our turbines. Just need the power cable. I amaze myself sometimes. The Puffins must be considered expendable in these terrible times. If the Irish or Icelanders claim it, we must regrettably send a gunboat. How it is. 😱
Re extracting energy from ocean currents:
Ocean Current | Tethys
Strong ocean currents tend to be further offshore than tidal currents, which tend to be found in coastal or inland waters. This leads to deployment in deeper water. As ocean currents are strongest higher in the water column, fixed substructures for supporting a turbine become impractical for harnessing ocean current energy. Instead, devices may be suspended from moored surface platforms or attached to buoyant structures tethered to the seabed. Electricity is produced from the ocean currents by coupling a generator to the turbine and power is transmitted back to shore via subsea cable.
You cannot generate energy without collateral damage of some kind. You either live in a cave, scratch out a living burning a bit of dry wood with minimal impact on the environment, or you evolve, civilize and leave a mess in your wake.
200 000 yrs ago, we started out on this journey. I just hope mankind will be here in 200 000 yrs
I was listening to the Midnight MasterMind last Night on BBC Radio 2.
Some Northern Lass called Sonja felt the need to phone up the resident meteorolgist DJ and ask him some clearly difiicult questions about the Solar System. Launched into some RAP that she had seen a Planet last night. "It were AMAZING" quoth she. 😕
I immediately detected she were some relative of Professor Brian Cox...
Anywhoo, here's her questions:
1: "Which Planet is the LARGEST in the Solar system?"
2: "Which Planet is the HOTTEST in the Solar System?" (Launched into some rant about greenhouse Gas and Global Warming...)
3: "Which Planet has SUPERSONIC Wind Speeds?"
I didn't get the last one right. She's a bright lass. 😱
The sun is still the best bet.
1000W per square meter at the surface of the earth perpendicular to the suns rays. We need 80-90% solar cells. There's a challenge for you @steve
Here's another idea. We tie a large steel rope between the earth and the moon. Since the moon's orbit is not exactly circular, but slightly elliptic, when it moves away, we can use it to LIFT say 10-15 billion tons of water in a large bucket.
You place electricity generation turbines around the bottom of the bucket, so that as the water drains out, the turbines are rotated, thus generating electricity.
Advantage: completely green
Simple. Effective. Pure genius. Almost as good as Bybees
Have you any info on practical schemes to extract energy from ocean currents, Pete?
I'll try to examine the possibility later.
Absolutely! There was a guy on Dragon's Den a few years ago flogging the notion of giant concrete slabs on a reciprocal generator that via a geared mechanism generates power in both directions as it is moved back and forth by the current (think of a blanket draped over a clothes line).
It could work as well as any other proposed system, but I am in no place to judge.
The investment of money, even to build a working experimental model, would surely be more than even the richest Dragon would be prepared to make.
Or, are you going to tell me that one of them took on the challenge?
