Again, the correct answer is live performance is superior to two channel stereo. Now, why does that matter?
Because two channel stereo is a compromise resulting from legacy technology. Multi-channel is better than two channel stereo at approximating live performance, therefore, multi-channel will increasingly replace two channel stereo as technology changes the relative value of compromises. Multi-channel is standard operating procedure in Hollywood and we see the music transition underway with Apple's Atmos and Tidal's 360 streaming audio offerings.
Sorry, but you are wrong again. It is not true that a live performance is superior to two channel stereo. All that can be said is that they are different. Two totally different experiences that serve two totally different purposes.
I think anyone that believes a system in their home can somehow magically transport them to a live performance in a theater is delusional. It’s not going to happen whether there are two speakers or 13 speakers all over the room and hanging from the ceiling. It just ain’t going to happen.
You are still in your room which is the main determinate of what you hear regardless of how many speakers are deployed. In fact, there can become a point where all of those extra speakers are a detriment to the sound quality rather than an enhancement.
If you want to keep believing that multi-channel is preferable to stereo for the best quality sound in listening to music that’s up to you. But trying to sell it here is not likely to go very far.
However, you might find better reception over on one of the home theater forums where sound quality is not as important as other things. Particularly, as trying to create an illusion that you have somehow been transported to a live performance.
I busted my 5" fullrange loudspeakers, sounded very good at listening volume and listening position but the kids demanded a party and the speakers couldn't reach party levels. Compression kicks in pretty soon and dynamics fall apart. Eventually after few kids parties wrinkles appeared to the metal cones. Otherwise sounded pretty good still at high volume, no bad sounding distortion. The portable BT speakers that are everywhere get pretty loud as well but sound really bad when loud. All home parties I've been with home stereo speakers have sounded quite nasty when cranked, the typical big-box store variety. High distortion in the local bars as well (small town).
Anyway, with big multi-way speakers party volume is reached without compression, problem solved 🙂 Lots of fun, loud and clean has some extra impact. Bought a cheap SPL meter recently to see how loud it is, haven't tested yet.
My pre-amp has the option of setting a limit on the stepped attenuator, which prevents that sort of damage. You would have been wise to pick up an old pair of 3-ways off a local buy and sell for dirt cheap and let the kids thrash them at the party. Preserve your full range speakers for normal listening. My local buy and sell site right now has numerous mid-fi multi-way "party" speaker pairs that are going for peanuts. Many come with amps or receivers. Stick them out by the wood pile with a tarp over them when not in use. 🙂 In my experience, there are few "critical listeners" at parties like that.
I should have been clearer, I'm still thinking of two channel stereo just than using two speakers might be a design trade off 🙂
...even for two channel recordings?
Yes, because it should be possible to have good imaging and adjustable spaciousness at the same time. People have mentioned in this thread that the room is a large factor, has that anything to do with loudspeaker design? 😉
closest to
what do You consider a trade-off in those designs that I mentioned?
Given that i estimate that the very best speakers are 20% of where we can go. If one takes a sampling of the finest loudspeakers available today, they are all equally valid loudpeaker designs and they will sound different.
Because compromises in the design cannot be avoided. And each designer chose a different set.
For instance an OB/Dipole has a specifi dispersion that classicalfan mentions, ha sthe immediate compromise of using an OB. When one choses an OB one is making significant compromise right off the bat.
Not right or wrong, just a choice.
BTW an OB is usually a poor dipole. But can be much more efficient and less costly.
dave
Why not? They each have sound going backward.<snip> dipoles and therefore provide the desirable characteristic of constant directivity. Not trying to compare them to omnis.
I was implying that despite their constant directivity as you say, they have (or might have) an early reflection component. What is it about dipole that people want, do they see the rear wave as inevitable or desirable?
To answer that question I might ask whether someone would want dipole, and yet not want omni?
Perhaps. But it goes beyond "loudspeaker design". It's more like system design.
Whereas the listening room is a factor that should be taken into account anyway.
"Loudspeakers and room as a system" ...there once was a long thread about it 😉
Worth saying again. The goal of trying to “match" a live performance is a red herring.
As soon as the live event (not many of those on CD unless one is a classical fan) is recorded, so much information is lost that there is no way to identically reproduce the live event. Besides a whole lot of other things.
As has been pointed out, that recording is a distillation of the event and may in ways be better than the erformance depending on where you sit.
And most songs today are artifical creations made in a studio with the (stereo) hifi as the intended output device.
The big compromise is that if one wanted to listen to live music exclusively as much as we listen to hifi one would need to have a huge space and LOTS of money.
And listening in your car & on the bus becomes very limiting.
dave
Not for me and many of the "authorities"The goal of trying to “match" a live performance is a red herring.
Why would multichannel, per se, be worse for sound quality than stereo?
1/ Cost: many speakers, many amplifiers, typically poor pre-amps vrs higher quality in stereo because of way simplier, way fewer compomnents to pay for.
2/ lack of recordings that take advantage of more than 2 channels.
But if all you listen to are movies…
dave
... it goes beyond "loudspeaker design". It's more like system design.
Another very good point.
And the system includes the room and the listener.
dave
Don’t get lost in the Maze Matt.
dave
I probably should have said more that two speakers rather than multichannel, although I am talking about music not movies, and apparently many movies have excellent sound.
Good points Dave. I agree.
Furthermore, there are two approaches to listening to studio recordings. One approach attempts to make their own system and room "disappear" so they are effectively (approximately) transported into the studio. The other approach lets the musicians into their room to play.
Adherents of one of these approaches like to claim that their approach is the "only way" to "true hi fidelity" and everything else is "mid-fi", while the others simply enjoy the sound of musicians playing in their living room, knowing it isn't perfect and not really caring.
I don't want to sit in a studio with musicians. I want them to come to my place and play. But to each their own.
I wouldn't want an orchestra to sound like they were in my living room, I'd rather it sounded like they were in a larger space.
- Trade-offs in loudspeaker design
