Train style car horns.
I need others' experience here.
I have a 2018 Ford Edge and the original, single element horn said:
'Excuse me, I hate to bother you...'
I updated it to the dual element and it's fine but it says:
'I hope you realize you shouldn't be doing that.'
Where I live, a horn needs a sense of authority and I'm getting too old to play that role. ie: I don't get out of the vehicle to encourage my point of view anymore.
I want one of those funky spiral train horn things that not only fits under the hood, it also gets their attention long before they need to know 4000 lbs. of vehicle can really hurt when not careful.
The internet is full of these horns but I am uninformed. Help me out if you can. Sample audio clips seem to be scarce.
BTW: The best answer receives a 'get-out-of-diy-jail-free' card personally signed by me, if you happen to have future indiscretions. 😉
"train horn" means air-horn.
https://www.amazon.com/Carfka-Electric-Compressor-Vehicles-Motorcycle/dp/B087FBQTY1
https://www.amazon.com/GAMPRO-Inches-Trumpet-Compressor-Vehicles/dp/B07QWS7YB4
https://www.amazon.com/COOCHEER-Trumpet-Vehicles-Powerful-Compressor/dp/B08913QH4V
Horns
Model 836 Silver Streak(R) DD 12-Volt 119 Decibels 376/383 Hz - Low Pressure - Truck Horns - Horns
This once worked on my 1961 SUV to save the other guy's life:
https://wolo-mfg.com/horns/specialty-horns/model-330-fun-horn.html
The air horns that played tunes were very popular in the UK until they were banned and now attract a big fine.
The horns can all play at the same time but not in a tune.
I suspect so people dont get confused with police/fire/ambulance horns.
Motor Vehicle Act Regulations
Copyright (c) Queen's Printer, Victoria, British Columbia, Canada
Horn
7.02(1) Subject to subsection (2), every motor vehicle shall be equipped with a horn which will emit sound audible under normal conditions from a distance of 60 m, but no horn shall emit an unreasonably loud or harsh sound or a whistle.
Sirens and theft alarms
(2) No vehicle shall be equipped with a siren, whistle or bell unless
(a) the vehicle is an emergency vehicle,
(b) the device is a siren, horn or theft alarm ...written permission from the director...................or
(c) the device is a theft alarm comprised of a bell, horn or buzzer.
[am. B.C. Regs. 205/72, s. 7; 343/77; 413/97, App. 1, s. 3; 135/2003, ss. 1 and 3.]
Standards for the Approval of a Motor Vehicle
Horn
8 A motor vehicle must be equipped with a horn as required by section 7.02 of the regulations.
The horn must be firmly mounted on the vehicle.
The horn control must provide a positive control over the sound emitted. A cycle of sound must be interruptible.
A horn must not produce a musical or any other sound not normally associated with a warning device.
The horn control must be readily accessible to the driver.
[en. B.C. Reg. 106/94.]
Hey Cal, I know what you mean. As a motor cycle rider I got sick of being invisible so added a 3 tube air-horn to my ride. Almost 50 years ago now. Sounded like a big truck horn and would scare the little darlings into looking around before trying to share my lane - it must work because I am still alive!
Readily available at so called auto-parts stores. The worst part was having to go inside and mix with the 4 wheel types but I washed my hands after and didn't catch anything.
If you get something that you easily can return, there’s not much at risk for trying it out. Just like speakers, best if they are big and hear’em with your own ears. In this case, with your neighbours ears 😀
Ultimate Blast Horn Canadian Tire
“ powerful sound with great intensity “
Amazon might be good from the perspective of on-line reviews:
https://www.amazon.ca/SoundOriginal...id=1607195980&sprefix=air+horn,aps,182&sr=8-9
or, if you want bigger
https://www.amazon.ca/MPC-B1-Trumpe...id=1607195980&sprefix=air+horn,aps,182&sr=8-6
Maybe notice that most of the big horns want 12V plus air pressure. ...
Notice that the Amazon and Wolo products I posted all HAVE a compressor. In this one, the lump top-left of the photo.
Yes, you do not get Westinghouse-grade AIR from a $13 compressor and no tank. There is a part-second delay until the horn reaches full wail. In the over-$130/set class you do get better air.
I do think the snail-horns are more appropriate here.
An air-horn on a motorcycle sounds dangerous to me. I'm the other driver, I hear a Big Air Horn, I'm not sure where, I want to get out of the way.... the (usually unseen) motocycle is not the truck, I'll tuck in there.
