That system belongs to Steve Mac ( over at Altec Users on Hostboard ).
The driver is a GPA 288H mated to a 511E sectoral .
Steve Mac's GPA 288H
( too bad all his pics are missing )
He also designed up + built those midbass horns ( housing Altec 515-16G I believe ).
Super Bad Cat
The mid-bass horn is a 210/211 converted to have non parallel side walls that was a continuing 'thorn in my side' when I cut mine out of some 210s to be part of a 4 way corner loaded system. IIRC he used the same compression box size I'd used for 515Bs with no mods. I don't remember how the flare factor [slope angle] was determined.
GM
That is awesome, thank you GM. What's a 210/211 horn?
Also, never seen such a bass horn, with no rear chamber. Does it work like an open baffle? Why no rear chamber?
You're welcome!
They're dual 15", ~70 Hz truncated expo horns in BR cabs:
http://www.lansingheritage.org/images/altec/catalogs/1978-pro/page05.jpg
Who said no rear chamber? 😉 'compression box' is a sealed rear box [chamber] sized to push the driver's Fs up to load the horn properly. If not attached to the horn it would be a high tuned sealed alignment with a big peak in its response [high Qtc].
That said, if the driver had the right Fs, Qts it could be used OB same as the pioneers did: https://i.imgur.com/GYqTr.jpg
GM
GM
Wow, I would not have identified those as 511s, despite having owned them and the 811s. Good call.
IIRC the subs are CV truncated bass horns ['c' fold] like used in [from?] a Sensurround system. All around, a bodacious system!
GM
GM
Just to say it again so there are fewer questions, the sectorals are 511E. They are for mounting the large format 1.4" drivers like the 288 and 290.
The 210 cabinet was used in A1, A2 and A4 systems. What Steve has is basically an 'improved' 815 cabinet.
Whoa, that is one interesting system to study. Perhaps build? Any site of forum where Steve Mac can be found to ask him some questions?
What I like about it is -- 3 way system yet a 2 point source. I believe this is much easier to integrate in a normal sized listening room of about 500 sq.ft. -- my listening space. Traditional 3 way horns are a no go for me.
If I understand correctly, this is a near point source from midbass up. Would be interesting to see how this midbass horn models and the system crossover points....
Knowing what we do about the drivers and horns, I would venture xo points of 80-100 and at 800-1.2k.
Steve Mac, while a member here, hasn't posted in a dozen years.
511E? Wasn't that a normal 511 with the flange moved up to the 1.4" section of the horn throat? I remember photos from years ago.
Not to my knowledge, but we communicate occasionally and I need to respond to his latest PM, so will ask him if he will share the expo Excel? WS he made.
Really though, if still online, anyone can take the throat, mouth area, axial length off the 210 drawing and 'run the numbers' to get the expansion dims. Hmm, actually, it can be done in Hornresp by using just throat area, axial length, flare frequency IIRC, so could make it a different aspect ratio and/or larger/smaller though of course it won't load as low if smaller.
True point source once digital time delay is used to 'move' the 511's driver back somewhere around/behind the 515's acoustic center at the XO point. Without this it's not that good of a sound system.
From experience I find it hard to believe it sounds fine without some aerodynamic smoothing of the 511, but he claims no.
GM
Hi folks, Greg alerted me to this post...good to see the community active!
Noviygera, I think you nailed the original intention of developing a large point source. It began looking at old Westrex designs, an article on shading WRT driver in driver, and then the Altec designs. Greg was instrumental in this design so always a shout out there to him. 😉 So, another intention was slightly elevated presentation while seated. The mid bass horn bolts together as well. I built what I call the wedges, which was the hardest part. Once they were done the side walls simply bent to conform.
Recently I removed the bass horns below and replaced them with JBL dual 18” powered sub-woofers.
So from a driver point of view:
2 Fostex T500AMKII horn tweeters
2 GPA 288H alnico drivers
4 GPA 515’s
2 JBL 2242H 18” -> now the dual 18 jbl powereds
Greg’s comments about the 511E’s edges may be true, but inside the home my general feeling is they are not driven like they would be in an auditorium so although I experimented with trying to curl the edges some more, I just couldn’t hear an improvement. My experience in audio was being subjected to the dozens of speakers my Dad and his friends were constantly experimenting with. And those fellas were all Altec, JBL, McIntosh obsessed. God bless them, they knew. 🙂
The amps in my system are Odyssey Audio mono blocks. The owner visited this setup before I added the super tweeters had me turn the system way beyond what I had done and I think it was surprising to him how the system did not blink. Also, he adnitted he had not heard dynamics like this. I know Greg and the gang regularly had issues with flea powered amps and dynamics. I think they were right.
The timing of this thread is interesting as I am moving the middle of next year and it’s not clear I will have the space for the mid bass horns, kind of an open question right now. But, honestly this system exceeded what my kinfolk worked on. I had them in a large room up in the Indy area and the stereo image was astounding. Because of the size, it just feels like you are in an auditorium and smaller speakers just don’t present the same “feel”.
I’m going to try and upload some images a little later.
Hi Cal,
For the 288s....~550Hz , 80 on the subs
- horn system id please
