More gain from EF86 RIAA preamp
Commonplace MC cartridge step up transformers have 1:10 or even higher ratios. 20 dB. of voltage gain will (likely) overload the tubed circuitry. Those 1:10 SUTs are routinely paired with 500 μV. O/P cartridges.
IMO, the Denon DL110 is neither LOMC nor HOMC. 🙁
I built the little head amp and it works okay. The real problem is the ELektor phono stage. It sounds really bass light. I may be flogging a dead horse here. Can I tweak the RIAA for more bass?
Does it comply with the RIAA spec ?
If it follows spec there is nothing to do in the riaa stage itself, but you could
turn your bass control up a bit.
If the RIAA is flat at least to 20Hz and you are complaining about the lack of low frequency response then we are talking about Power at the bottom end or should I say Drive ?
I have built many preamps and make a point of making sure its flat down to 20Hz , what I found is that exact values of capacitance/ohm-age are required for a high degree of flatness even values of "around 1% " are not really good enough .
JLH actually built up values to make the response a very high degree of flatness--complaints were--- "we cant get those values" or "that's extra work for us " which I don't accept .
It is clear when you look at the circuit that low-frequency RIAA conformity will be poor. The RIAA stage is essentially an inverting op-amp stage with the op-amp replaced with the EF86, but there is nothing in the feedback network that levels off the gain below 50 Hz: if the EF86 had nullor/ideal op-amp properties, the gain would just keep rising as frequency decreases.
That means that the frequency where the gain levels off is inversely proportional to the open loop gain of the EF86 stage, which won't be very accurate. It depends on the EF86 transconductance among other things, which depends on the age of the EF86. A fresh valve will give you more bass than an aged one.
You can tweak the open-loop gain and, hence, the lower RIAA cut-off frequency to some extent by using a fresher or older EF86 or by tweaking the anode or cathode resistors.
And thats exactly the reason why this is just a mediocre sounding phono stage and not an "excellent one" as Elektor claimed. They could have done better, fulfilling their marketing paroles to deliver high class circuits for the techies and clever people. But they just delivered to them one of the many versions of low quality phono stages of the golden era of tube sound, when expectations for home audio wasn't high end.
Thanks. Can you suggest some values I could try?
R5 = 150 kohm and everything else as is, or
R6 = 1 Mohm, R5 = 180 kohm, everything else as is.
Mind you, this is based on very approximate calculations, so you may have to experiment a bit.
By the way, it is essential that the output only gets loaded by R7 and the 500 kohm potmeter. If you would use a lower value for P1 or connect a line input straight to the EF86 without the JFET buffer, that would reduce the gain of the EF86 stage and shift the first cut-off frequency.
You've nailed it, MarcelvdG. When I built he preamp I used a 250k pot instead of a 500k one, after I was advised it would make no difference. I'll change it for a 500k one and see where that gets me.
Thank you.
