GU-50 triode
OP is operating point (Ua, Ia).
Plate curves might look good in terms of power, but low load values will cause poor speaker damping - like 6-7 Ohm (depending on the OPT's primaty and secondary DC resistance) of output impedance for 8 Ohm speaker tap.
That might work OK for some types of speakers, but for conventional modern ones it most likely won't.
I laid out some loadlines on FL152 triode curves at Va = 375V, Ia = 65mA (attached). They show single-ended lines. As I understand it, for push-pull operation in class A, double the impedance (a 3.5k ohm SE loadline means a 7k plate-plate Push-Pull OPT).
Assuming FL152 characteristics are close to the same as for GU50...
As I see it, GU50 in triode needs a pretty high primary impedance compared to the more commonly used power tubes like EL34-triode, 6L6-triode, KT88-triode, 300B, 2A3. To me, it looks like you would want to use a 10k p-p OPT for GU50 push-pull class A operation. You'd also want that OPT to be capable of delivering at least 30W before saturating. That's a tall order. (Higher impedance OPTs are more challenging to make perform well than lower impedance ones.)
Take a look at the 1750 ohm loadline (3.5k p-p for push-pull). That does not look good to me at all. Nearly vertical, which suggests high levels of odd harmonics in the distortion spectra.
Do you agree, or did I get that all wrong?
First thanks for your pains.
But perhaps i missed something or i don't understand how push-pull amps are working but the voltage at input B+ is 300v .
Working point will be near 90ma 150v vg=-10v
With 100Ω at screen.
R=1,75k
R=1,75k
1) The OPT stores energy, so you plot the loadline differently than you do using a load resistor. Here's a good basic explanation of single-ended tube output stages:
The Valve Wizard -Single Ended
And here's the push-pull explanation:
The Valve Wizard -Push-Pull
2) If your B+ is 300V, then the voltage at the GU50 plates will be 300V minus whatever drop there is across the primary resistance of the OPT.
If you're using cathode bias (self-bias) then you'll need to subtract the cathode-to-ground voltage from the GU50 plate voltage (actually the plate-to-cathode voltage).
So, with a B+ of 300V, minus (let's say) 5V dropped across the OPT primary resistance, that will now leave 295V at the GU50 plates.
3) With -10V bias, and assuming you're using cathode bias, the GU50 plate-to-cathode voltage (Va) will be 285V.
Where did you get operating point of Va = 150V and Ia = 90mA?
Not really a problem, it's just far from optimal.
GU-50 is a cheap high power tube, and it really makes sense to use it at high power only - like 400V/100mA or something like that.
There are a plenty of 12W tubes (say, EL84 and 6V6 families) that are much better sonically and require half of the heater power.
