How do i fix vintage germanium amplifier from a record player ?
Reverse engineering is a fruitfull steep way mastering electronics, and germanium antiquity stirs a lot of brilliant dinosaurs here to help you out. Who's going to post the proper circuit drawing first?
And I've checked my local supplier: AC180 and AC181k or GE replacements are still available.
Almost correct🙂
Is the "diode" connected in series with 27 ohms or in parallel?
Most likely Ac127 / 128 is closed.
It would be nice if you measured the voltages across the bce (relative to the total) across all transistors (working and faulty) for comparison.
Have a look at the schematic link - your circuit is not exactly the same, but it indicates how to better draw the output stage transistors. Your circuit doesn't have AC180/181 emitter resistors, and the transistor mounted on to one of them is in the base bias circuitry to normalise output stage current as the output transistors heat up.
Registratore a cassette G19/151 Ampl/Mixer Geloso SA; Milano
It's almost the same as this.
The object attached to the output transistor is a thermister - negative temperature coefficient device - to keep the bias in check when the amp warms up.
Almost correct🙂
Basically "diode" or what ever it is is connected between bases of both output transistors so yeah it is in parallel with 27 ohms resistor, As far as measuring voltages goes do you mean from ground to each leg or across the legs of the transistors? I will do the measurements later and update you all.
OK here is what i found out. Basically fault seems to sometimes get worse and sometimes better. I was testing the amp and it worked decently. Faulty channel was still quite and distorted but it worked and after powering it off for a few minutes oscillating is back at only half a voltage. I recorded a video of the fault.
Sorry for my bad English i get really confused when i speak English in front of the camera lol
Broken amplifier - YouTube
One more find !
When i turn it on i have to wait for it to stop oscillating and then rise the voltage and then wait again until i reach full voltage and if I disconnect the power for more than a few seconds it starts oscillating again for a short period of time once I re connect it. The longer it's unplugged the longer it is oscillating when power is applied. And when i get it to full voltage working channel is nice sounding and strong but failed channel is weak and "dirty " sounding
