Eagle question
It doesnt work to right klick,no menu shows up just a short sound i the speakers.And the tools in the panel doesnt work either.
It´s the free verison.
Edit: What is tracking mode?
Well you are either laying down traces, or placing parts, or editing footprint, that sort of thing.
Each mode has it's own context menu accessed with a right click, normally.
The sound in the speaker is a dead giveaway; you are trying to do something that is impossible or not allowed in the current mode.
So if you are laying down tracks, you can't add or delete a part. Normally you need to go out of the mode and into another. Often by clicking a different icon on the tool bar.
Jan
An examle I am starting from scratch now with the SG3525 in the schema,all is fine but when I right click on theSG3525 and that sound commes and nothing more happends.
I press the move button in the toll bar,but that is not working and that is with only one component on the sheet.
Is that a pre-loaded example with that chip already on? Try a blank sheet and then add that chip. Can you move it now?
Jan
No I can´t find any lock.
It is like I have ben trying for a while to move the SG3525 on the board so if I try 36 times and the doa little work in the schema section and then go back to the board yhen on the 36st time it works very strange..
Wich CAD prog are you using?
Hello Ake,
you´ve to pick the component at his origin, for BC transistor located at square pad, for SG in the middle.
I´d no issue with your layout!
PS: please check selection filter (Youtube Autodesk EAGLE for tutorials).
JP
I would try to see "properties" for that SG3525 , maybe right clicking it or selecting it and opening the component editor or whatever it´s called, and checking it does not have a "lock in place" flag selected or something equivalent.
The thing is it doesnt work to rightclick,nothing happends just that soud in the speaker.
Thesymbol is completely "dead"however I can route to it.
I discovered that the Eagle free´s board size is not big enough for the design.
So I have 2 options spread it on 2 pcb´s or use another softaware that doesn´have this limitation....
