Aural hallucinations mostly consist of hearing voices.
Not when it comes to audiophiles.
Have you never wondered how pretentious it is to declare yourself to belonging to some 5% with superhearing. While passing by every opportunity to validate this with controlled listening tests?
Therefore, until further notice, it is 14%, just to make you a little less special. And illusory until proven otherwise.
In which way could that be an explanation (or even justification?) for any hostility?
Often "better" includes "I prefer" , at least it is my impression, but it must not; but anyway, why don't you think that readers are not able to get the subjective side of such descriptions?
Does it really happen that some new members (totally naive) trip in this thread, and believe anything that is written herein?
It is often not expressed, but for a claim to be regarded as "extraordinary" there should be a lot of contradictionary experimental evidence exist, it is not sufficient that somebody (or even a group) believes it shouldn't be possible.
A nice example of deflecting, obfuscating, nitpicking, strawmanship, and <drums are rolling> FUD. The essence of Jakob# contributions to the DIY Audio world, in a nutshell.
I don't know of anyone who has made such a declaration. In fact, I have flatly stated I have less than normal hearing, including some loss at HF.
To make a guess, could be you ignore too much when you listen.
He's probably thinking of Bob whose over the moon since he discovered he was actually in the ~2% 😉
A nice example of insulting, snooty, contemptuous, infatuated and <personal attack> POST. The essence of Ovidiu#A nice example of deflecting, obfuscating, nitpicking, strawmanship, and <drums are rolling> FUD. The essence of Jakob# contributions to the DIY Audio world, in a nutshell.
Jakob(x) should add you to his resume as a reference. I'm sure it will do him a lot of good
Ok, let me rephrase that: to some 5 % with average hearing but super analytical hearing skills. It still is 14 % and illusory until proven otherwise.
It can't. And look what seems to happen to those to whom it does matter. I'm not envious, are you?That what i tried to enlighten, talking to "back and forth". How can a difference hard to perceive in an immediate comparison can matter, comparing to he differences that occurs to each of us between two days, with different air humidity, temperature, various musical sources and personal mood ?
...It still is 14 % and illusory until proven otherwise.
How do you feel about ScottJ and PMA claiming to hear a 100kHz rolloff in a recording of a preamp?
(You may recall PMA said there is no other explanation besides that they heard 100kHz rolloff phase shift down in the audio band.)
So, 14%?
Would you say, maybe 5%?
Personally, I congratulate them both for trying to listen carefully, for succeeding at hearing a difference, and especially for having the courage to say so in this place.
Don’t be a hater! 😀
Hey.....anyway you count it there seems to be a disconnect somewhere,
I’ve found things I was hearing (that shouldn’t be heard) during the voicing of my last speaker xo, THEN tried to figure out what it was I was hearing. It wasn’t like I plugged in a new piece and and it kept getting better.....there was a whole lotta worse in there too.
When I get to the indifferent point that’s as far as it goes.
There’s something to this, I’m sure some egghead will stumble onto the math that makes whatever it is happen.
There will be much crow eaten! 😛
You should re-read all your contributions. >90% were well resumed by my pastiche, including this one.Jakob(x) should add you to his resume as a reference. I'm sure it will do him a lot of good.
In your place, I would try to understand what frustrations make you so angry and aggressive. Prince Vlad III Basarab was one of your ancestors ?
Putting yourself in such a state for such a derisory subject as that of DIY of high fidelity equipment is not reasonable, it is hardly imaginable how far you could go on something more serious.
Something like what you describe is probably possible for lots of people under the conditions given. Perhaps unwise to induce chemically. Thankfully not unassisted/involuntary hallucination in a fully waking state.
Hearing both voices and music in white noise is common. (with no added assistance to the brain's constant attempts to pattern match).
Not only that but hearing Morse code SOS messages, as experienced by radio operators on ships. Happens when S/N is very poor.
That's because I have golden ears 😉 BTW planet10 attempted to undermine my hearing acuity by searching through this thread and quoting my numerous posts about my tinnitus, I advised him to ask you about the validity of his assumption, I'm guessing he never did?How do you feel about ScottJ and PMA claiming to hear a 100kHz rolloff in a recording of a preamp?
So, 14%?
Personally, I congratulate them both for trying to listen carefully, for succeeding, and especially for having the courage to say so in this place.
...guessing he never did?
Will let you know if it ever happens 🙂
That statement has no basis in fact, "that which shouldn't be heard" has not been established.
Thanks, it won't, it was a while ago now.Will let you know if it ever happens 🙂
Yep, I deeply regret not having used my famous "scare quotes" and in addition I missed my double negation, which makes it even more worse.... 🙂
There’s a certain tone in my wife’s voice when’s she aggravated that makes me stop hearing voices.....wonder what percentage of men have that happen? 😀
The phase from a single 100kHz pole starts well into the audio band.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part IV
