You've not said what your headphones are. If I were you I'd start a new thread which would then be dedicated to your questions about amps. Describe what you want to do and I guess helpers will appear. On this thread I guess few will want to derail it in order to help you in detail.
Giordano, you should start a Beta22 headphone amp thread when you start building it. It has the best topology and AMB Lab provides the most helpful and comprehensive instruction among any DIY project that I had seen. Excellent result should be a given if you follow the instruction carefully. I will love to hear your build journal.Hello,
Where is the Beta 22 thread?
At "Home > Forums > Amplifiers > Headphone Systems >" I switched to descending order of replies, and I could not find it. Maybe I'm overlooket, I hope, but I can't believe there is no thread for the Beta 22?
I've just decided to make one, 2 channel probably, running on 2 small 12V SLA battery. I was looking to read build experiences etc ... It is strange for me that I could not find it on a very popular amp.
JG
AMB have very complete description, including detail parts number, of needed components. But there is no complete BOM for Mouser or DigiKey yet.
This is not a cheap project. I wish I can hear one of the built unit someday. Best wishes for your adventure.
Does anyone know if there's a DIY or kit version of a THX AAA amp?
I've been auditioning "high end but not insanely priced" units lately, as I want something for my band's live cue system (I need six of them)
The Hood's nice, the Atom's nice, the O2's nice... but the THX has a slight bit more solidity in the LF, (even single ended) which is very important for this application. Granted, that might have something to do with a better power supply design, but I suspect it's both.
$400 is a bit pricey for me right now, esp when I need six. I'd LOVE to roll my own, if possible,
Cableaddict,
I would seriously look into Tom Christiansen’s new HP2 design if THX level performance is what you are after:
HP-2 – Neurochrome
He has a thread in the Vendors forum...
Best,
Anand.
HP-2 – Neurochrome
Best,
Anand.
And Ti is a super guy. Agreed...his build instructions are awesome. I also think that Tom Christiansen’s/Neurochrome instruction manuals are awesome. I use them both in many of my diy SS projects.
Best,
Anand.
Can anyone recommend a DIY Balanced (XLR in) Headphone Amplifier for under $400?
Don't know how much it might cost to build, but possibly the best HPA in this forum is cloned in a thread here: Pass HPA-1, what do we know? ...listening tests during design of the original were mostly done with Audeze LCD-X.
It is the same HPA design as: Pass Labs HPA-1 headphone amplifier | Stereophile.com
That said, I have a Neurochrome HP-1 and find it great for analytical work when I want to evaluate distortion of another device by ear. Did find it has a bit of RF sensitivity at the inputs.
There's a fella selling a 2X BUF634 board on eBay -- the only difficulty for some may be that it uses SMA connectors.
Of course, I am partial to Dr. Marsh's HPA compact with vanishingly low THD%, but I have a horse in that race having sold hundreds of PCB's (at cost). The input JFETs aren't quite as easy to source as they had been.
LT1210 is a high current, current feedback amplifier -- if you look at the datasheet there is an example using a precision opamp (LT1097),
LT1210 is rather expensive, but in the TO-220 version easy to heat-sink and wire up. I've used it (to inject a signal into a power supply for measuring PSRR). If you are going to use the LT1210 you can not in the least be inattentive to layout.
Not found composite amplifiers on LT1210
My composite is on LF357/LT1210 . Gain at 20kHz 123db
Non-inverting composite with embedded OOS .layout
Actually it's a Walt Jung composite amplifier
changed LT1210 correction to increase loop gain.
A simpler amplifier is a copy of the Walt Jung composite
The "WHAMMY" definitely belongs to the "Best DIY headphones amp" list.
I just finished building one and I am floored by the quality. I also measures really well, see my measurements below:
"WHAMMY" Pass DIY headphone amp guide
(currently running MostFet outputs at 80mA)
Cableaddict,
HP-2 – Neurochrome
Best,
Anand.
I am not much of a reviewer mainly b/c everyone has their own preferences. However, I agree with Anand wholeheartedly. I have one of Tom's HP2s, and it is a fabulous HP amplifier. I never had the opportunity to hear the HP1, but the HP2 seems to certainly fit another poster's previous request for a "reference" style amplifier and would also line up with THX level performance. Tom stands behind all his designs, and I can say I'm very, very happy with the HP2. I use it with 32 Ohm planars up to 300 ohm Senns and everything in between.
Did anyone ever build the SOHA2 from headfi of old?? I still have a kit unbuilt somewhere in my workshop!
Also as far as I can remember the Bijou all valve balanced headphone amp was Another very highly regarded headphone amp.
I do not normally join discussions about "the best of ....".
But XLR (balanced) input does not always mean a fully balanced amplifier.
An example is the single ended Borberly EB602-200, which will accept differential inputs.
https://www.diyaudio.com/forums/hea...borberly-eb602-200-revisited.html#post5492287
But of course you can also go fully symmetrical, such as a F5X-HA.
F5 Headamp ?
And if you like the sound of zero global feedback, then an XCEN followed by a discrete LH0033 Sziklai actually sounds very nice.
XCEN Balanced to Single-Ended Converter Revisited
XEN ZGF Portable Headphone Amplifier
http://xen-audio.com/documents/xen-zgf/ZGF Desktop Description V1.pdf
Merry Christmas,
Patrick
F5 Headamp ?
Merry Christmas,
Patrick
I made this years ago from a Danish audio magazine, bd139-bd140 class a, sounds amazing still, lots of power.
Think I still have files for it.
Hi, Nice diy amp - I'd love to see the schematic, thanks.
As for best DIY HPA -
Marsh headphone amp:
Marsh headphone amp from Linear Audio
and Whammy !!!
Here's one I made for a friend that can be done on the cheap... it's a 6p15p parafeed. Granted it is geared towards 55ohm headphones it wouldn't take much to optimize it to your cans of preference... especially seeing how the output transformers can be had for $10. Best sounding headphone amplifier I have ever heard. I am proud of this one. There is a small bug in the schematic... it doesn't show the center tap of the power transformer, and it should be grounded.
- Headphone Systems
- List of best DIY Headphone Amplifiers
