Hifonics Zeus Z440
I picked up and older Hifonics Z440 and went to power it up and none of the LED's light up. I opened the case and it looks like someone was in here. Iam not sure where to start trouble shooting this one. Here are a couple pictures. Any help would be greatly appreciated. Thank you!
When you connect power and ground of your power supply to the amp you should have 12volts when you measure with your volt meter between power and ground at the power terminals. If you have power there then leave your black probe on ground and check the center leg of the power supply mosfets. You should have 12 volts there. If not then you have a problem with your power supply, the fuse, or an open trace on the bottom of the board.
Connect the remote power now along with the 12 volt battery and ground. With the black probe on ground check for battery voltage at pins 8,11, and 12 with the red probe. Pin 12 is connected to the remote turn on voltage. That will make the chip operational.
If you have correct voltage there then check pins 3 and 4 to see if they are below 3.5 volts.
If these pins go above 3.5 volts it will shut the chip down.
