LM317 as CCS
This is dead horse and I know it’s not a great CCS due to non-linearity, but I put a 317 set to 45mA on the cathode of my 807 SE amp by passed with a 100uf cap and it starts collapsing as the signal increases. Drops the cathode voltage down to around 2V at full tilt.
I popped in a 250ohm resistor and instantly get way cleaner sine waves at nearly twice the output power before clipping. What causes this? Non-linearity wouldn’t cause what I’m seeing I don’t think.
Thanks!
A CCS for a SE amplifier needs to have a time constant in the feedback loop that is longer than the lowest frequency required by the bass bin.
If this is not true the bass will be clipped by the CCS starting to regulate before you want it to start working.
Push pull amplifiers are a lot easier.
Yes. The bypass cap is not pictured here, but the 317 is.
