Temp. vs. wattage in soldering. Which do I need?
Hi everyone:
My Weller WP25 iron doesn't seem to provide enough heat to melt solder quickly. It's rated as having a tip temp of 750° F, yet it takes too long to melt even standard low-temp leaded solder. I don't want to risk damaging any components.
I'm using a decent-sized chisel tip, so that's not the problem. I tin the thing constantly. It's shiny, that's not the problem. I know my basic soldering skills quite well. That ain't it.
Now, my question is, does an iron with higher wattage but similar or even lower temperature melt solder faster in the same situation, all else being equal? I ask because I was thinking of getting a Goot px-201 iron, which has a max. current rating of 70W and mostly excellent reviews.
It's temperature regulated, so either it's too low in power, or broken.
Weller tips should not need tinning in normal use. Do you wipe it
on a wet sponge before each connection? Does it work ok on just a small
pcb pad? Does your solder have a rosin core, and is it eutectic (63/37)?
YES
pcb pad?
Not very well. It's still very slow to melt solder.
Yes. I've also tried 5 kinds of solder.
Ironically, I do very little soldering. But when I do, I want it to go smoothly in terms of not damaging components. The heating element in the Weller is almost new. I can't imagine it's bad. I got it from an authorized dealer. It's also always been this slow, from the first day I tried the iron.
If You do a lot of soldering consider a soldering station.
I use this cheap one and works fine.
Soldering Station Pro'sKit SS-216E (110V/220V) - GsmServer
For de-soldering I Use this one with standard 1mm & 1.5 mm tip
DENON INSTRUMENTS, SC7000Z, DESOLDERING GUN, STATIC DISSIP | eBay
There are others for rework & hot air, but I do not much smt's or Plc's soldering.
Let's assume my Weller was working properly. Will the PX-201 with
much higher wattage be likely to melt solder more quickly?
It should take only a few seconds (say 2s-5s depending on thermal mass)
before the solder melts, assuming reasonably clean surfaces and tip,
and use of flux. Review some YouTube tutorials on soldering to make sure
that your technique seems ok.
YouTube
YouTube
YouTube
