How to save a laptop that has been on hold for five months ? Is there a way to access the computer without entering a password as i forgot its login password.
If it is a windows user password, not an issue, remove the hard drive, place it in a usb caddie and copy your files on to another computer.
If a hard drive password. That is it, no way of recovering any data.
Or boot it from a bootable USB pendrive with Linux, then you get access to the HDD. There are also rescue CD-s around and good descriptions on their use on the net.
If the hdd has a password, it is not possible to access anything, not even to re format the drive! But, we don't know which password is involved. So we are guessing.
Thanks , can i boot it from bootable USB pendrive with Windows ?Or boot it from a bootable USB pendrive with Linux, then you get access to the HDD. There are also rescue CD-s around and good descriptions on their use on the net.
Assuming Windows laptop and drive not encrypted or otherwise locked.
Many small Linux distributions/utilities can blank or allow new password to be set. Just pick one and write it to bootable USB stick.
However, Win-fricking-10 may cause more problems if it is creator's update and the drives are never really closed (WIN10 tends to hibernate/Suspend leaving the drives apparently active). In which case you will need to boot at least a small Linux dist to "remove_hiberfile" to mount it r/w.
You may need to web search a little to refine the method.
J.
Sure , make a bootable USB disk for your locked laptop , which can be used to reset your login password ,Thanks , can i boot it from bootable USB pendrive with Windows ?
One of the best USB tool Hiren's BootCD PE
Boot with it's own Windows and explore any HDD, contains a lot of usefull tools.
E.g. great for flashing bios with windows-only utility on linux machine. But I could not find how to access usb drive from hirens, I had to copy the needed files to HDD first...
Strange, which motherboard ?But I could not find how to access usb drive from hirens
I use it from very long time and no problem to access USB.
Maybe yours have USB 3 that drivers missed in Windows and have to add it, search for "Add drivers hirens boot usb".
Thanks for the info. It was an older server (xeon e3-xxx), booted from CD drive - a bit more difficult to add drivers. But I will look at it, thanks.
Or with its help to create a bootable USB , then boot your laptop from it , the login password can be removed ,then you can access your laptop .
Get it : How to Access/Unlock A Laptop without Password in Windows 10/8,8.1/7/XP
One way to unlock computer is to make a bootable USB,another way is to login your computer with other user account (MS,Super account and Guset account)
have a look on google they will explain you step by step process through which you can easily do this
I have got one : WinPWD Windows Password Recovery - Best Windows Password Reset Toolhave a look on google they will explain you step by step process through which you can easily do this
And here is a free one: John the Ripper password cracker
Here are some steps to unlock the laptop without password.
1: Insert a Windows installation disc on your victim computer and reboot from it.
2: Select your native language and hit next. Click on "Repair Your Computer" link from the bottom corner of the screen.
3: Select "Troubleshoot" followed by "Command Prompt" to launch the command prompt window.
Step 4: On the command prompt screen, type the following line and press Enter: net user Rocky NewPassword
5: Replace ‘Rocky' with your username and "NewPassword" with any password of your choice.
6: Restart your computer and use the new password to get into your computer again.
- PC Based
- Save the old laptop
