Hi guys,
It’s not really a direct scale down of the LS. It’s a 0.67 scale down but with some dimensional changes cause he added the wedge at the the corners of the box. I’ve verified some measurements against the LS.
assuming no big changes - it should behave about the same.
IF you could stand tall and skinny - 0.83X31.5" ! 26 inches tall - not much more than a foot wide. *RCA-Fan's D120 horn at 0.83X)
real horn might behave different - -Bill rebuilt this one a bit different - but was not satisfied. (it still looked pretty good by my standards 😀)
I think this type behaves somewhere between the offset and end driven model.
In a corner it does 130dB (28.3v) down to 80Hz w/o exceeding xmax
Would be nice if I can find some vintage 10 inch deep cone paper woofers that has similar specs. There’s something about their tone in horn boxes.
Thank you again
Electrovoice EVM 10L, Fs=65Hz, Qes=0.175, Qms=5.8, Qts=0.17.
So 2*Fs/Qes=743Hz.
Yep, guitar driver, good call
; I had the Altec ER-10 'on the brain', but is pretty rare these days and had totally forgotten about its EV variant. 🙁
GM
GM
The filter slot in the drawing looks about 8.6 x 2 inches, this downsized from the origional 13 x 3 factory size. If you are really sawing wood, try a 8.6 x 4 inch filter.
With horns larger is better, why not build a 2 x 15 inch woofer version? With appropriate drivers a 110dB/watt mid-bass horn.
- really like the look of that double 15 W - bin and assume one per side for stereo would be fun. EV 10L/M seem scarce. B&C's 10FW64 has fairly low (but higher) qes than 10L with more xmax as tradeoff. I could use some input on another Karlson box - whether to add a stub, picking cavity depth, etc. Glyph - do you have a good handle on K traits? Any cool horn which isn't huge (has to be shipped from a builder 2K miles away) would be highly welcomed too. I have FH1 (like to get rid of them to make room for other toys), Sentry IV bottom, 0.7 scale "Classic".
been up for nearly 24hr w. little sleep - so can't see well
ID=48.20
Ang=2.0 x Pi
Eg=2.00
Why didn't you just copy the file into the export folder, then post as an attachment? Super quick/easy and saves us the hassle of converting to a .txt file, etc..
GM
Hi Gents,
Thank you all for the wonderful advice & tutorial.
Wow the EVM 10L sure looks good spec wise.
In the mean time I think I found a better woofer the Delta 10a.
Here it is : OPEN BOX B&C 10FW64 10" Professional Woofer 8 Ohm
Cheers
Cheers
I apologize GM - sorry - don't know where to store folders - just pictures at Imgur. 10FW is a feisty looking driver - like a somewhat higher qes version of a 10M with higher stated xmax.
Hi Freddi am awaiting to find out how much is the shipping cost.
Well it’s on sale & only about $10 more then the Delta 10a.
Should be worth trying out you think ? Lol
Thanks again
Thanks again
re:600 - don't know if a scaled down Thunderbolt could get that high -
scale this drawing using the 15" speaker frame for reference
for fun Delta 10a in the little 0.66 La Scala vs a 0.7 size Thunderbolt - like a trumpet vs a tuba
(I cut the LS back chamber size down to flatten ts passband)
Thanks Freddi for taking the time to simulate.
Couldn't wait so I bought the B&C 10FW64. Lol
Slightly OT question, I've got an JBL 2432H 1.5 throat but my horns throat is only 1.4 inch, question can just mount directly or do I need machine lathe to open the horns throat to 1.5 inch as well.
Thank you again
The Bec curve do look nice & flat.
Thank you again
I'm trying to figure out a Karlson for 10FW64 and have been looking at it for several years
here's the 0.66 scale La Scala with 10FW64 with back chamber sealed vs vented
FWIW I've recommended/used an inexpensive variable speed hand drill, 3 stone brake system master cylinder honing tool to do this or can make a thin metal gasket with a hole that's ~[1.4*1.5]^0.5 in diameter as a stepped taper that's only going to be an issue way up high where our hearing acuity either is very poor and/or can't hear that high [>20 kHz].
Adapters if the extra HF length of horn is desired: 1.4" to 1.5" horn adapter - Google Search
GM
btw, two 10FW64 in William Cowan's 2-10" bass horn look pretty good in corner sim. I wonder if his assumption of a corner's mouth extension could be used with other simulation ?
60 Hz horn for a 10" driver it's rather large though 😉 DIY 60 hz crescent horn - The Paper Horn by Inlow Sound
- Small La Scala Tutorial for noob
