Audiolab 8000a Background noise/hiss
Dear all
I have a Audiolab 8000A here. It sounds great, works great but is no longer low noise. There is a constant background noise/hiss. This is present also when no input signal is applied and the volume is at zero.
On the power rails (measured on the big 10000uF caps) I also see this noise in addition to the ripple. It's just everywhere.
I usually repair Leslie Tube Amps and Hammond Organs. There, bad caps usually make hum.
Of course this Audiolab Amp is probably old enough to change the electrolytics anyway, but could this be the reason for this kind of noise?
Any hints would be very welcome and thanks in advance.
Christian
Administrator
Joined 2007
Thanks, I just wondered on the speaker question. It is odd that both channels are affected as well.
Try isolating the power amps as Jon mentioned, that's the first line of attack. If you can actually see noise on the rails to the power amps (what amplitude?) then that is very strange indeed. Make sure you are using the correct circuit ground point when you check that (not the chassis) because I'm wondering if the chassis is floating in some way... dunno :) … you need to do more tests and narrow things down a bit.
Yes, that's why I thought the cause might somehow be a noisy power supply...
I just fixed an Oberheim OB8 Synthesizer. There, also a lot of noise on the power rails was an issue. Recapping the power supply and exchanging the bridge rectifier and the regulator improved the situation considerably.
Tomorrow night I will have time to proceed, so you will hear from me on Saturday....
Administrator
Joined 2007
I wouldn't like to second guess this one tbh, deteriorated caps in themselves would not allow HF noise to appear on the rails, you would just expect an increase in ripple... however could an increase in supply impedance (deteriorated cap) cause the amps to become unstable in some way.
Very odd. Lets wait on the results of test and measurement.
Tonights findings
Ok, here is what I found out so far:
1) I do not have the correct schematics for my PCB Issues, partnumber and values differ. However I managed to remove the correct parts
2) Removing 47u capacitors in the line/tone amplifier circuit (C315/C316 in the commonly available schematics, C508/C608 in this unit) reduces the noise by a factor of 5:
Measurements - Google Photos
3) Reinserting any of the two caps brings back the noise level on the according channel
4) Removing the 4u7 cap after the volume control (input of this stage) increases the noise level considerably
5) The noise level on the +30V power rail is more than 2 Vpp !!!!!
So I still think it is the noise on the power rails, this also explains why I see this noise everywere..... There are many transistors in the power supply, so tomorrow I will look there.....
Administrator
Joined 2007
Firstly make sure that you are using the correct ground for the measurements.
