Do I really need to mention the other end of the resistor returns to the battery?
Yes, in fact you do. It makes a very significant difference how the return current gets back to the battery.
You are claiming something with respect to prop velocity, but not worried about the entire current path? That is not how it works..
Velocity of propagation requires both conductors, as you are speaking about the e/m field moving along the conductors.
A large loop carries with it higher inductance.
jn
The conductor resistance then comes into the signal propagation velocity (for low frequency or bandlimited signals) because it adds to the series impedance, and at really low frequencies it may dominate over the inductance.
I don't see what you mean here. Reduce it to a simple resistance and complex load, phase or group delay are not propagation velocity per se.
You are just so rude.
Wait...wrong thread..
jn
I know. I can't help but think an attempt is being made to relate the Fermi velocity of the carriers to the propagation velocity of signals and lumped models are for electrons as particles and transmission line models are for electrons as waves. I have decided to stay out of this I'm sure you can handle it without being rude.
https://www.europhysicsnews.org/articles/epn/pdf/2004/02/epn04201.pdf
I mean this is old and stuff, but if we're talking about controlling the speed of EM propagation through a medium, strangely relevant.
And fun. 🙂
And fun. 🙂
The jury is out on that...😛I have decided to stay out of this I'm sure you can handle it without being rude.
The question "why is the other wire that returns current important" tells me everything I need to know.
Jn
Ba dum tss.The question "why is the other wire that returns current important" tells me everything I need to know.
Jn
Well as I see it one ampere of current is a coulomb of charge passing through a conductor per second. Now for some confused folks this is not the same thing as how long it takes an electron to do that. The electron that enters the conductor carrying the charge is not the one to quickly leave.
In my one meter long cable it takes about 30 nanoseconds for a charge to first enter before one leaves due to the finite propagation velocity. As a coulomb per second is 6.24e18 ish charges per second 30 nanoseconds worth would require about 1.87e11 charges to be in transit in the one meter wire per amp of current.
In my test apparatus there is a test signal of around .01 volts driving the cable under test and the load is over a megohm or a current of less than 1e-8.
That would leave 1.87e3 charges transiting through a one meter test cable at any instant.
Theory and Calculation of Transient Electric Phenomena and Oscillations - Charles Proteus Steinmetz - Google Books
Hopefully this links successfully. Might this help?
The top speed the charge can travel down a wire has to with the drift velocity of the wire material right?
Oh boy. Electron drift velocities are microscopic. The density of free electrons is gigantic. Start here and read the example of a 2mm copper wire: Drift velocity - Wikipedia
Huh? The topic of discussion has been around cable construction, as silly as it is, where propagation velocity is going to be constrained by the dielectric. And also this is entirely meaningless within the essentially DC bandwidth known as audio. Even respecting what jneutron cites about extremely small phase changes with frequency.
How about my question, if 90-100% of cables used from the artists to the LP/CD are PVC, why are we trying to improve on that? What do we have to gain? Are we "losing" something in sound for every increment of dielectric after the original process? Did the recording studio lose something because they don't have fancy cables? 🙄
What function of audio playback system has an issue with propagation? Do we have a dysfunction because some slew rate is too slow but it would equal out with improved propagation speed? What is the *problem* it would fix, if any?
Now, don't get me wrong, I like insulation that is easier to deal with... And I don't want high capacitance. But we aren't talking about using garbage, at least I don't think anyone is...
😀😀I hope jn has the patience I will only get into trouble.
The shortest project I've worked here is over 10 years in the making. I have patience for the long term.
Think dead pool, Zamboni.. Ed on the ice...five minutes...
Jn
Hmm. I think I misplaced something here...what was it.. Hmm..
Oh yah...the other wire. Remember, the one where charge is going the other way??
Hmmm. Some dead guy comes to mind..Norton? Thevenin? Kirchhoff?? That's it. Kirchhoff, captain of the enterprise....space charge, the final frontier...
Jn
Ed.. Imagine a sphere around your battery. At every instant in time, the number of electrons within that sphere remains constant. Electrons that cross that imaginary sphere outward in one conductor are balanced exactly by electrons crossing that sphere inward on the other conductor.
For a step function, the current is dependent on the reactance between those two wires.
Jn
Jn
Pretty clear the number of electrons in the conductor does not change. Push one in another pops out. Not sure where the idea arises that anything else happens
Ed, they won't let this go, current has to flow in a loop and how it gets back affects what happens as much as how it gets somewhere. Therefore you will need to specify something, wire over ground, coax, twisted, etc. It matters when you get down to arguing about edges and wave equations, etc.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
