John Curl's Blowtorch preamplifier part III
Chris,
40 year old electrolytic capacitors do not quite perform as new. I tried to estimate the ESR but the real issue is that it is an axial type. They have a folded aluminum foil strip to allow the guts to slide into the case. That raises the inductance by quite a bit over axial construction.
As the custom labelled yellow capacitors were Tecate Mylar ones and my stocks had both Tecate yellow mylars to make up the required 80 uF and the polypropylene ones I chose the polypropylene ones.
If I get the chance I will measure the old ones. For obvious reasons I did not change any of the internal wiring, as thin as it is.
However my OPINION is that the room is at least as important as the loudspeaker.
As to modding the tweeter, may get around to that.
My units are Mylar caps but not mirrored HF. Very pleasantly surprised at how well they held up. I did loose my Acoustats in a flood 13 years, 2 months, 6 days and 18.5 hours ago.
Disabled Account
Joined 2012
On a different topic, I just refoamed and replaced the electrolytic crossover capacitors with a polypropylene type in my 40 year old Dahlquist DQ-10s.
Unlike RNM I am using an indirect field for the sweet spot.
Good idea to finally change out those caps for polyprop for greater clarity.
Most people listen in far field (indirect) and have to contend with room acoustic issues and its major affect on the sound/accuracy.
THx-RNMarsh
I had DQ 10's with the mirror image and film cap upgrade as well as Dick Sequerra's ribbon tweeter, I usually listened near field. They used basically the large Advent style woofer and the stock cheap piezo was problematic.
I would not call them "accurate" but they gave one of the best simulations I have heard and still miss them at times.
That's part of it, in conjunction with the connection wires,what's in the 'earthing' box sets up a 'vibe' that influences the behavior of the whole system and forces the system components to 'play nice'....or not.
Music theory/practice dictates tones that 'play nice' or 'not nice' together with consequent influence of mood/vital signs of the listener.
Physical elements that comprise the system cause subtle system sounds that similarly influence the listener.
Toxic elements used in circuit paths and enclosures/insulations cause toxic subtle sounds and consequent toxic effects in the listener....ROHS directive benefits go deeper than keeping heavy metals out of land fills/water tables.
Earthing boxes and the likes of BQP set a 'tone' in the system, good or bad.
Dan.
I feel this interesting post deserves a reply............ the only thing that springs to mind is a strange kind of wonder.......how would it effect toxic music with toxic words written by a toxic mind and listened to by a toxic person having toxic thoughts?...........
Joined 2002
my 40 year old Dahlquist DQ-10s. Also cleaned out a lot of dust. Surprised at how good they still sound.
Currently running on a 10 watt class A amplifier. More importantly the room was built to enhance reproduction. No doors to the next room, took out a bit of wall to be sure the space coupled. Wood floor with two oriental rugs. 10' ceiling and artwork on the walls. The largest is about 25 square feet and makes a nice bass disperser.
Hi Ed
Most intriguing post, for the reason it comes from you.
Had you chosen speakers of different directivity pattern and had decided in near field listening scenario, you would have needed some kW of amplification per your calculations.
You have plenty of first hand experience with high or controlled directivity speakers, high power amplifiers, DSP augmentation and realistic SPL playback levels.
You certainly have no "accessibility" issues for such systems had you wanted to use them at home .
My question is why you went the other route for your home audio system?
Thanks in advance
George
George,
On my large systems speech intelligibilty is the primary concern.
At a concert I have spent more time backstage than front of house.
Folk and small group classical music is what I would use the DQ-10s for.
One of the great bits of humor here is the wide variety of opinions on perceived sound quality. Much of this is sort of strongly hinted at by Fletcher and Munsons work. Folks who listen to louder music often complain of lack of bass response from actually quite flat energy response loudspeakers playing other varieties of music at lower volumes.
Did a stadium once or twice where the local operators were recording studio types. Not a good thing to leave them in charge of the tunings!
Figure for 40++ years I have listened to what is called an acoustic event every week. Also have heard a bit of amplified live performances. Surprisingly they don't sound the same. ;)
Joined 2002
Ed, yes.
I have formed the opinion that you have a respectable amount of experience in acoustics both as a professional as well as a listener (one enriches the qualities of the other).
That’s why I asked the question what makes you go for a low power amp driving a wide/non controlled directivity speaker, no DSP for far field listening in a not heavily treated acoustic space at home, although you have the knowledge to properly choose to go all the way differently.
George
The DQ-10s could probably be greatly improved by getting rid of the crazy amount of diffraction they generate.
Don't get your drift here, they imaged an over the air broadcast by Victor Campos like nothing I ever heard before or since. This was FM radio through 80's electronics. Around this time a $50k Thiel/Cello setup drove me out of the room.
My anecdotal subjective experiences from distant memory are as valid as anyone else's. The great pile of metadata.
